    Apr 2006
    I have an MKV file that I am converting to DVD using HCenc, DGPulldown and Avisynth. After the conversion, the Audio and Video are out-of-sync. After numerous failures, I tried Quenc and Dgavcdec and got the same results. According to Mplayer and Mediainfo, the video is 25 fps and the audio is VBR. At this moment, I am trying to see if ConvertXToDVD 3 will work as a last ditch effort. Below is all the pertinent file information and any advice would be appreciated. Also, for the Audio, I have used FFMpeg and MKVExtract to get the audio.
    Here is my Avisynth Script for HCenc
    DirectShowSource("C:\mymovie.mkv", audio=false)
    LanczosResize(704,464,76,0,552,400)
    AddBorders(8,8,8,8)
    AssumeFPS(25)
    Here is the info from MediaInfo
    General #0
    Complete name                : C:\mymovie.mkv
    Format                       : Matroska
    File size                    : 140 MiB
    PlayTime                     : 23mn 30s
    Bit rate                     : 833 Kbps
    Movie name                   : RxJ - FINAL - OMG!
    Encoded date                 : UTC 2007-12-06 01:49:36
    Writing application          : gdsmux
    Writing library              : Haali DirectShow Matroska Muxer 1.7.359.22
    Cover                        : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
    Video #0
    Codec                        : AVC
    Codec/Family                 : AVC
    Codec/Info                   : Advanced Video Codec
    Codec profile                : High@L5.1
    Codec settings, CABAC        : Yes
    Codec_Settings_RefFrames     : 15
    Bit rate                     : 726 Kbps
    Nominal bit rate             : 726 Kbps
    Width                        : 704 pixels
    Height                       : 400 pixels
    Display Aspect ratio         : 16/9
    Chroma                       : 4:2:0
    Interlacement                : Progressive
    Title                        : Video
    Writing library              : x264 - core 56 svn-680
    Encoding settings            : cabac=1 / ref=12 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=726 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.9:15.0
    Audio #0
    Codec                        : Vorbis
    Codec/Family                 : Vorbis
    PlayTime                     : 23mn 30s
    Bit rate mode                : VBR
    Channel(s)                   : 2 channels
    Sampling rate                : 48.0 KHz
    Title                        : Japanese Audio
    Language                     : Japanese
    Text #0
    Codec                        : ASS
    Codec/Info                   : Advanced Sub Station Alpha
    Title                        : English Subtitles
    Language                     : English
    Chapters #0
    1                            : 00:00:00.000 Intro
    2                            : 00:00:46.110 OP
    3                            : 00:02:26.110 Part 1
    4                            : 00:09:28.100 Part 2
    5                            : 00:20:40.200 End
    Apr 2006
    Please disregard. I found an old post by the poster Midzuki that helped fix the problem and the MKV is now on DVD with no A/V problems. For those interested, the thread can be found here
