any ideas what could be the problem
If your specs are right, 256mb might not be enough memory, and your processor might be too slow
If the file is large or high bitrate, or uses a more complex codec like h.264, you need a faster CPU to decode properly
It might be that your video is using an obscure codec that even VLC has problem decoding
You can use mediainfo (view=>text) to find out information about the video -
It's broke?
Really, without more information nobody would be able to answer your question. What are you playing? If it's a high Def or highly compressed like a MKV rip of a Blu-Ray video with a filesize like 25Gb, VLC may have problems.
Or it could just be a messed up video file that VLC is struggling to play.
What lags? The video or the audio?
The format is determined by the codecs used. What audio and video codecs does the file have and at what bitrates? Easiest is to post a Gspot screenshot of the video. Blank out the titles if wanted. One guide for screenshot posting: https://forum.videohelp.com/topic271697.html
And welcome to our forums.
Could you share your solution so other members may be able to benefit?
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Which Free Media Player can play this without audio lag?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Feb 2011, 01:58 -
I pop in my dvd's, it starts to play, the video/audio lags
By rko2164 in forum ComputerReplies: 5Last Post: 11th Jan 2010, 21:53 -
Sync audio starts-ok but near end 1 sec lag H.264/MPEG-4 AVC AAC LC
By JoeBolden in forum Video ConversionReplies: 6Last Post: 7th Jan 2010, 15:31 -
VLC Media Player hangs and starts hogging lots of Virtual Memory
By shiningwizard in forum Software PlayingReplies: 2Last Post: 27th Aug 2008, 09:17
