I'm going to Iraq and trying to put my dvd's on a 500gb external hard drive so I am using DVD Decrypter and AutoGK but AutoGK is takes an hour to do compressibility test and now it is doing a second one. I chose 700mb to make it quick. Any ideas on how to make it faster?
You could use "Target quality" rather than a predefined size. File size will be unpredictable since it will use whatever bitrate is required to get that quality level. The default setting is pretty good. Try it and see.
Using target quality , Autogk won't do a compression test and it will only run one pass, rather than two. -
If it's a newer DVD, especially from Sony or a few others, DVD Decrypter won't work. Try ripping it first with DVDFab HD Decrypter and you may find AutoGK doesn't have that problem.
And welcome to our forums.
Premiere Pro - Export to DVD - Taking forever
By nharikrishna in forum Authoring (DVD)Replies: 13Last Post: 12th Oct 2010, 05:47 -
Converting video from .ts format into .wmv taking forever. Help?
By pokeychris in forum Video ConversionReplies: 1Last Post: 21st May 2010, 11:29 -
AutoGk Stuck In Vista On Compressibility Test
By nhgawe in forum DVD RippingReplies: 4Last Post: 6th Jun 2009, 22:27 -
Taking forever to use virtualdub denoiser filter.
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 17th Aug 2007, 03:00 -
DV capture taking forever
By Kihon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Jun 2007, 14:08
