Always used this forum/site for problems and usually find a solution but couldn't find one for my problem.
Got myself two MKV files which have been split at some point.
I have used mkvmerge gui before and its worked with no problems at all.
Now because (im assuming this) the mkv was previously joined and split, they both have the same track ID's
When joining in mkvmerge I get part 1 played twice in a row and no sign of part 2.
The errors:
So I tried to extract the audio and video track out seperatly from the two mkvs, join the video files (which failed to work)Code:Warning: matroska_reader: Could not keep the track UID 609880219 because it is already allocated for the new file. Warning: matroska_reader: Could not keep the track UID 2715930044 because it is already allocated for the new file. Warning: matroska_reader: Could not keep the track UID 489503935 because it is already allocated for the new file.
Any help would be appreciated. Pretty new to this whole mkv codec
I will help you ten years later because this thread is still coming up when people do a search:
Open the file with mkvtoolnix-gui.exe from portable version of
https://www.fosshub.com/MKVToolNix.html
Do not click on Add source files > Instead, *DRAG* the first source file to under where it says Source files:
Then *DRAG* the second one > which now opens the Adding or append... window so you can select:
Append to an existing file.
Do the same for all files you wish to merge.
Optionally, go to the Output TAB and select: Generating chapters: One chapter for each appended file.
In case of further problems with say 5 files, try appending File 1 and File 2, then separately Files 3, 4, 5, then finally merge the two newly created files.
Additional info:
https://mkvtoolnix.download/downloads.html#windows
This can also be done inside Avidemux:
https://sourceforge.net/projects/avidemux/files/avidemux/
File > Open first file >
File > Append
Be sure to select the correct Audio Output [copy] and correct Output Format.
In case of problems with many multiple files, try to merge fewer at a time.
how to extract an audio track form MKV files??
By Sh@DY in forum Video ConversionReplies: 2Last Post: 15th Sep 2010, 07:42 -
Joining multiple .mkv files?
By Charmer in forum Video ConversionReplies: 6Last Post: 24th May 2010, 22:52 -
Joining AC3 files on a AVI or MKV?
By CactusMan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2010, 20:44 -
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 05:31 -
Joining 3 MKV files sequentially.
By Coinop in forum Newbie / General discussionsReplies: 9Last Post: 2nd Jun 2009, 07:56
