Hi. i have an original game in dvd dual layer, i made an iso for backup. i wanted to burned it to have a safe backup, but im having problems getting dual layer discs. is there a software that burns my ISO into 2 dvds of 4.7GB. If so, it will automatically ask for the second dvd when I install it?? Thanks.
Hi-
No. If a game, I usually split it into a bunch of RAR files and then split them up among 2 DVD5s.is there a software that burns my ISO into 2 dvds of 4.7GB. -
Exactly.Originally Posted by manono
Except that I don't create "bunch or RARs" but just few RARs with up to 10% recovery (if enough space).
Using any virtual drives is so easy, just extract your dual-layer ISO to hdd when needed and mount it up. -
What i do is if the file system is simple enough i split the cab files so 4.cab,5.cab,6.cab etc. go on disc2 and the first 3 cabs and other related files go on disc one.I make disc1.iso and disc2.iso and virtually mount disc1.iso and install and if it asks for disc2 or 4.cab then i mount disc2.iso and finish the install.
So if all goes well i burn both isos so if i need to reinstall i can use 2 discs and keep the master copy locked up.No need to unrar.The number of cab files i listed are just for example,there can be more or fewer.I think,therefore i am a hamster. -
Wo, sounds pretty good, splitting .cab files, but how do you split cab files?
On the other hand, if I manage to get dual layer dvd media, and burn it, could I install it from the burned disc without problem? i read something about PTP - OTP stuff.
Possible to burn a single 8gb file on a DL disc???
By moggsy in forum DVD & Blu-ray WritersReplies: 22Last Post: 11th Jan 2011, 21:09 -
8GB DVD into two dvds
By patelmiral in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 17:23 -
Encoding in 720p to single or double-layer DVDs?
By broaddd in forum Blu-ray RippingReplies: 2Last Post: 12th Feb 2009, 00:41 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
