I am thinking about buying a Canopus ADVC110. But have been unable to determine if Pinnacle Studio 10 will accept it as a capture device.
Has anyone used the ADVC110 with Studio 10?
If you have what were your results.
Thank for any help
Jim
My ADVC-100 worked once with Studio 8. Capture as DV.
You may need to turn off device control in the Studio preferences before it will accept a continuous stream. Otherwise it may hang up waiting for a nonexistent camcorder to cue to preroll point. Some software handles this automatically, others need preference settings.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Renting a Canopus ADVC110
By thesmackdown in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2009, 21:34 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 16:09 -
New ADVC110 does not show up as available capture device
By tonyp2 in forum Capturing and VCRReplies: 16Last Post: 12th Jun 2008, 21:01 -
Possible to capture hd from hdvr using ADVC110?
By john22 in forum Capturing and VCRReplies: 6Last Post: 2nd Aug 2007, 21:09 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
