I have converted avi into a pair of m2v and wav files. I still need to specify chapters and convert them into vob and other files for the DVD. What's your preferred way of doing this? I've used IFOEdit's author tool in the past but noticed that it wasn't compatible with some players. PgcEdit is more highly rated but I'm not sure how to author DVD with it yet -- some help?
Well, MuxMan is pretty easy to use if you don't need menus. I don't remember what format the chapter information uses on MuxMan as it's been a while since I've used it to do this, but I think you have to take
time in seconds * frames per second (use 30 for NTSC or 25 for PAL or maybe 24 if you are absolutely sure you have progressive video with a pulldown flag) and use that for each chapter stop. Some tools like DVD Decrypter can pull out the correct chapter info that MuxMan can use, so just rip out the chapter info from some DVD and look at it and you should be able to figure out how to do it. -
Please use manono's suggestion of 29.97 fps instead of my 30 in doing your calculations for chapter points as there's just enough difference in my rounded off 30 that it might cause your chapters to be off by a few seconds by the end of the video.
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 09:52 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 19:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 11:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 14:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 21:33
