Hi guys,
Firstly, i'm a newbie.
I want play video which is on my computer on my dvd player(panasonic dmr-ex87) via a SD card. jpeg files work fine, however, videos do not.
Specs for dvd player sd card slot - video: codec: MPEG 2 (SD-Video Entertainment Video Profile).
The video files that are MPEG Movie (.mpg) and MPEG Movie (.mpeg) what is the difference? They both dont work.
ive been told by pana that the sd on the player is for their video camera and not designed for the way I want to use it. though since that jpegs work i thought video would work and that I was doing something wrong!
btw, i know i can put whatever on a disc though i want to see about using sd card.
any help?, thanks. blowfly01
If the device isn't designed to do it, then it won't happen. Panasonic have already told you that it isn't designed to play back video from SD cards, so you might as well accept it. I have a Samsung Series 6 LCD TV that will happily play back jpeg images and mp3 audio from a USB flash drive. I can put as much video as I like on it, the TV won't play it because it isn't designed to do so. The Series 7 will apparently play back video from USB HDDs when released. If it is possible, Panasonic might release a firmware update at some point that changes the functionality, but it might not be possible with the current circuitry anyway.
Read my blog here.
Convert the file to MPEG2 using MOVAVI. Available on free trial.
Use MULTIAVCD (free download) to process MOVAVI mpeg-2 output file.
Choose Panasonic Viera SD card with NTSC if in USA or PAL if in Europe.
Copy SD_VIDEO folder (output from MULTIAVCHD) to SD card.
Play video on TV
Play Video on 10 year old Notebook?
By AEN007 in forum Software PlayingReplies: 33Last Post: 14th Jan 2011, 09:07 -
Can Blu-ray DVD player play both of photos and video clips from an SD card?
By coody in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Dec 2010, 12:11 -
Help finding DVD player+recorder that can play NTSC DVDs on PAL TVs
By kumi in forum DVD & Blu-ray PlayersReplies: 13Last Post: 30th Nov 2009, 22:33 -
DVD-R burned using a DVD Recorder wont play on any other player
By weaseal4 in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 12:37 -
dvd recorder or usb tv / video card
By faithzzzz in forum DVD & Blu-ray RecordersReplies: 5Last Post: 13th Sep 2007, 11:09
