Well my 1tb external drive is full of ISOs of DVDs, so I thought I would reduce the size a little.
I'm taking just the movie and 1 audio track and running it through FairUse.
My conversions look pretty good on my standalone player.
I haven't tried any conversion back from AVIs to DVDs
What do you thing about my settings?
I always choose 720x480 in the previous screen and I've been clipping the credits off
I always set it 2gb file size too
Screenshot of the settings
Any other way to get better quality a 2gb usingXvid for a standalone?
Results 1 to 16 of 16
I never thought about too high of a bitrate
Here's just one screenshot. Most seem to be around 2500, one was 5600 though
Just from what I've read on this site, I thought Xvid/Divx bitrates over about 2000Kbps were problematic with some players, though no personal experience.
I guess I'll burn one of the highest bitrate ones to a DVD to see
Edit:
Just tried a movie burned to DVD that was 4856Kb. It also happened to be over 2gb
Can't figure out why, but most all have been 2048 or so. The last 2 have changed in size. One was 2366mb and the other was 2750mb. They were all done with the same settings
BTW, my standalone DVD player didn't have any problems playing it. However it did take it a little longer to read the indexing at the begining -
That's good that the playback works well.
I picked up a cheap Philips 3960 Divx player a week ago, but haven't had any time to see what capabilities it has. Most all my Divx/Xvid/H.264 videos are on the servers, but I wanted something to test for compatibility on set top players.
One big advantage to the high bitrate is if you do decide to convert one to MPEG DVD, it should preserve most of the quality. Most of my Divx/Xvid encodes are around 1.5GB and I find that sufficient for my needs. But since they are DVD backups, no real reason to convert them back to DVD format.
I do plan to convert some of my older DVD rips on the server to H.264 and that will be at about 1.5GB also, so I should have a good comparison to the Divx/Xvid backups. -
That was another idea I had.
Use a high bitrate so if there was a case I HAD to convert it to DVD, it would look half way decent. Of cource it wouldn't be 5.1 anymore
I did try to keep the original audio streams using autoGK, but the audio sync was off as much as 20 seconds sometimes. This was the main reason I switched to Fairuse for a converter -
stiltman - Why not keep the 5.1 track in FUW? On the last page before encoding begins, just select AC3 instead of MP3. FUW will not alter the orginal sountrack.
I keep all of the original AC3 tracks, but I use Quantizer 2 instead of setting my own size value. Each DVD is encoded at a different bitrate. Telling it what size you want is great for fitting on discs, but will produce various results. You may not be able to tell the difference between two DVD's, but coverted to Xvid may result in noticible quality differences. My videos converted at Quantizer 2 are stunning on a 32" TV, and some are considerably less than 2Gb. -
DOH!Originally Posted by Almost Human
OK now using AC3, Thanks!
I trying a full test right now.
AC3 quantizer 2, it came out to be 1.3gb and the bitrate was around 1500
Now I'm trying the same movie but changing it 2gb size, 2 pass no quantizer
Want to see if the average bitrate will increase
Edit:
I set it to 2gb but it came out at 2.3gb
Bitrate went from 1500 to 3000
Edit 2:
I see what it's doing. If I set it to use the AC3 audio untouched, it just adds that on to the file size at the end.
In this case AC3 was 300mb and I set the file size to 2gb, so in the end the final file was close to 2.3gb -
How setting it to 2gb file size is pretty much random with the movies I've trown at it so far. I thought at first it wasn't taking the audio strean into account, but that's not it. I've been encoding movies 3 times each now to get the file as close to 2gb as I came
Strange -
Anyone know how to *force* Fairuse to stick to the set file size?
It seems to be a total crap shoot. All DVDs are in ISO form on my HDD
Last night I did the same movie 4 times before I got it to be close to 2gb
1st time set it to 1999mb and it ended up at 2568mb
2nd time set it to 1850mb and it ended up at 2307mb
3rd time set to 1750mb and it ended up at 2218mb
4th at 1700mb and it came out to 2107mb
All of them used the same untouched AC3 at about 400mb
Next DVD I tried I set it to 2gb and it came out at 2045mb
It had an AC3 of 360mb
Total crap shoot -
OK I seem to be having problems with a few encodes higher than 4000kbs burn to DVDs It will start out a little jercking (first couple a minutes) and then settle down a bit.
Is there a way to reduce the bitrate a little without having to go all the way back to the begining with fairuse (aka using the original DVD or ISO)? Some thing easier than putting the DVD back in a gain.
Looks like I'll be keeping all my encoides under 4K for now on
Why waste the time? Fry's has 1TB Seagates for $149 and rumor is they may be down to $99 by Black Friday.
http://www.slashgear.com/early-black-friday-forecast-149-blu-ray-player-499-40-inch-pl...ma-tv-1916790/Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Got a couple of questions, but first let me say my standalone has no problems playing either
I started out using FairUse with the defualt settings but upped the file size to 2GB
Then after someone posted that I could use the original AC3 audio I went with that.
However I didn't realize it also changed some other settings.
My questions
Whats the difference between:
MP3 Audio
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : XVID
Codec ID/Hint : XviD
and
AC3 Audio
Video
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Muxing mode : Packed bitstream
Codec ID : XVID
Namely what BVOP, @L1 or @L3, Simple vs Streaming, Packed or Unpacked
Also, even though I set the profile for "home" which shades out packed bitstream, it still encodes with packed bitstream for some reason.
If you need the whole media info text, just let me know
Newbie questions, I know, but hey the answers will sure help out others I bet
STreaming is for sending stuff over the webistan, so it try's to keep below a max bitrate and probably trys to keep a more constant bitrate. use unpacked and divx home theatre profile. keeping files under 4gb allows them to be burnt to a dvd-r.
There is no way of "shrinking" an mpeg4 file, re-do.Corned beef is now made to a higher standard than at any time in history.
Originally Posted by RabidDogI set it to 2gb file size with AC3 audio. I noticed it will go to unpacked if I convert the AC3 audio to MP3.Also, even though I set the profile for "home" which shades out packed bitstream, it still encodes with packed bitstream for some reason.
Archiving old Video 8 videos as MP4 question
By ShaneJensen in forum Video ConversionReplies: 7Last Post: 25th Jan 2012, 04:40 -
Question about video archiving on my Mac
By kealolo in forum MacReplies: 18Last Post: 11th Sep 2010, 15:23 -
Fairuse wizard "Resolution/AR" question!
By UnD3R0aTh in forum DVD RippingReplies: 6Last Post: 18th Mar 2010, 06:14 -
Fairuse Wizard
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 05:38 -
Newbie question about archiving on DVD recorders
By Soupcan in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Aug 2008, 22:58
