Hi everyone and thanks for taking the time to read my post. Ok this one has had me tearing my haor out for weeks now. I have always used convertxtodvd to burn my avi files to dvd disc and it has worked fine that is untill one day whilst halfway through the conversion stage i get an error messgae saying transcoder has stopped working. I have tried it on previous avi files that had previously burnt ok and it gives the same message.
I have tried different versions of convertxtodvd and that gives the same messgage even after i have use vso clean and reinstalled the software. Even a complete reinstall of windows vista 32 holds no joy.
Ok now i tried dvdflick to see if that would burn ok but know it just keeps stopping at the video conversion and says ffmpeg.exe has stopped working
ashampoo burning studio gives me the blue screen of death .
The thing is wen i try to run these programs on my old xp machine they work fine.
Obviously this is a program with the conversion process (trancoder stopped working, ffmpeg.exe has stopped working) but i cant find any fix for it after forum hunting it seems lots of people have had this fault but no real answer.
Can you good people help i help.
Have you installed any codec packs ?
Have you installed the latest video card drivers ?
A BSOD usually means either hardware or drivers. FAVC should not care about video drivers, so perhaps your problems lie elsewhere. Next time it blue screens you need to get the number associated with the error.Read my blog here.
or a memory issueOriginally Posted by jagabo
If he has more than one stick of memory, he should try one of them at a time -
Think i got it and it was the pc heating i wiped away some fluff n dust off my fans and grill and hey presto it worked time for a clean out me thinks
MPC-HC, VLC work after restart, later produce errors
By ringo12 in forum Software PlayingReplies: 4Last Post: 29th Jul 2011, 12:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
Can't get XVID to work, Vdub+Moviemaker errors
By nhgawe in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2010, 20:39 -
encoded .avi to dvd errors?
By mrjust in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 22:37 -
Is there Any software that will correct for tracking errors on a DVD?
By hitechluddite in forum DVD RippingReplies: 7Last Post: 19th Jan 2009, 12:32
