Does someone now the Hack for Mustek v300k to multi region?
I dont now if the hack of v300 work on v300k but if someone now please tell me.
I need to now this the most fast possible.
thanks.
Have you tried this:
No Disc in player
In Remote press setup
Go up-down-up-down-up-down on your volume button on the remote until it says "v 1" or "v something"
Use the buttons you go up and down in the menu with, until you get v255 (that is zonefree - no region)
Just exit menu and you are done
Worked beautifully on my Mustek V520
There is another way I know of (which didn't work on mine)
If you haven't already tried this method, then try it:
http://www.komplett.no/mlf/produkt/diverse/mustek.htm
Good Luck!Once again monkeys will rule the planet
Reverse Multi Region Hack
By squiddma in forum DVD & Blu-ray PlayersReplies: 2Last Post: 30th Mar 2010, 08:33 -
Multi Region Hack for Sharp DV-sl1200w
By gilljaz in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jun 2009, 05:00 -
Multi Region Hack for Soniq QPD120B
By hammertime in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Mar 2009, 13:00 -
help on region hack Philips DVD963SA from German to US/Multi region
By stieven in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 13:29 -
LG DNX190UH-NEED A MULTI-REGION HACK PLEASE
By vonbek14 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 18th Jun 2007, 16:54
