When my authoring with GFD exceeds 4.7G dvd disc capacity (with a red bar at the bottom showing I am over the limit) & when I select "Auto calculate shrink" I always get the message "No shrinkable video". Due to this I get the output from GFD and then shrink it again to 4.7G using DVDShrink. Any workarounds? Thanks.
Yep. Use a bitrate calculator to caluculate the correct bitrate needed to fill your dvd. Then encode your mpeg with that bitrate.Any workarounds? Thanks.Donadagohvi (Cherokee for "Until we meet again")
meaning dont start with more titles than the disc capacity? This is what I am doing currently when I want to add say two titles which add upto around 5GB. A two step process - first reauthor & shrink them using dvdshrink (with the single VOB per title option) and then reauthor again using GFD to add the graphical title menu. It does work well for me, just that it would been nice to do this in one step.
GFD is an authoring tool, so you can either re-encode your video before you author, or author, then re-encode.
If you are doing the original encoding to mpeg-2 then you should make sure it fits at that stage. If you are taking material encoded elsewhere then you either follow the options I started with, or use a different tool that can re-encode as well as authorRead my blog here.
GfD uses "requant" to shrink m2v files when necessary.Originally Posted by pannayar
See the help under "Notes to shrinking (requant)".
You can use it manually: on the loading file window, in the "Videofile" section there is a checkbox:
"Use Requant to shrink" and then "New Video Size" (in MB) or "Factor" (in %).
Note that it only works with plain video, (eg, m2v) not including audio (eg, mpeg). Maybe that's your problem.
If so, demux and author with separate video and audio and GfD should be able to shrink the video to order.
Or you can use ReJig, which is actually based on the same code as requant.
Pretty fast and gives good results, at least when just shaving a few percent off.
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:00 -
Background picture looks bad DVD authored with GUI for dvdauthor
By stars in forum Authoring (DVD)Replies: 10Last Post: 10th Feb 2009, 04:32 -
Creating Dual Layer DVD with Gui for DVDAuthor
By RKDYork in forum Authoring (DVD)Replies: 3Last Post: 19th Jun 2008, 20:01 -
questions about using GUI for DVDauthor to author DVD
By jimdagys in forum Authoring (DVD)Replies: 8Last Post: 2nd Dec 2007, 20:08 -
No Audio on GUI for DVDAuthor DVD
By dennis albright in forum Authoring (DVD)Replies: 15Last Post: 15th Jun 2007, 12:05
