I want to convert and send some my DV films to my friend to Canada.
I'm not sure that he has SVCD compatible DVD player and, of course, my films are in PAL format. So, could I put on the same SVCD disk any software player, which he could install on his PC? Which one? How about DVD player compatibility if I add some software on SVCD disk. Any hints?
I'd like to be sure that he will be able to use my disk on PC or DVD.
Not many software DVD players will handle SVCD's but WinDVD does.
Go to their homepage and download version 2.3 (as this doesn't require registering unless you wanna play AC3 stuff)
Good luck. -
So, with that player I could just put on SVCD additional directory like WinDVD and my friend will be able to install it from that disk?
Small question - can PC read SVCD content as data CD-ROM? -
>So, with that player I could just put on SVCD additional >directory like WinDVD and my friend will be able to >install it from that disk?
Yes - but bear in mind that your SVCD writing software can put much more on a CDR than you can using normal create CD. IT doesn't use as much error checking, so you get more space, so if you leave plenty of space you might get away with it. (Tried this last week, ended up sticking WinDVD on a second disk !)
Yes SCVDs are readable on a PC, but it's Mpeg2 so only DVD players can read it,.. and then only two (in practice) seem to want to have anything to do with them!! Trying to read them via mediaplayer won't work.
VCD's are easily readable though.
Send image from laptop to TV
By a_2008 in forum DVB / IPTVReplies: 2Last Post: 9th Nov 2010, 05:41 -
Adjusting xvid Soft Subs Size for dvd player?
By spiritgumm in forum SubtitleReplies: 7Last Post: 27th Jun 2010, 12:39 -
Want to purchase good DVD Upconverting 2.0 USB Player in Canada
By scharfg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2010, 23:50 -
How to send video of window media player thru mail
By rajshri in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2009, 12:46 -
How send 1-hr DVD over internet ?
By rdfarr in forum Video ConversionReplies: 11Last Post: 8th Apr 2008, 23:22
