Hi, does anyone know of a good freeware video cropper?
Results 1 to 10 of 10
What kind of video?Originally Posted by Milardo
Do you mean cropping time, or the image? -
For wmv you can use windows media encoder or windows movie maker.
Is there one that lets you manually crop the video not have to enter values.
VirtualDub:Originally Posted by Milardo
Video/Filters
"Add" button: choose "Null Transform"
"Cropping" Button:
Now you can drag the sides to crop.
Video/Compression: choose your compression settings for output file.
(If you don't do this you will get HUGE uncompressed files.)
Then "Save as Avi" . -
Thanks for the replies. I found out that mediacoder has a similar crop feature. I think I will use that.
Freeware to capture a shot from a video or DVD?
By gastrof in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jul 2011, 03:11 -
freeware video converter
By aruwin in forum Video ConversionReplies: 3Last Post: 16th Jan 2011, 00:28 -
Freeware App To Change Video File Size, But Not Video Or Audio Codecs
By LouieChuckyMerry in forum Video ConversionReplies: 4Last Post: 19th Jun 2010, 09:06 -
Video repair freeware/shareware?
By will7370 in forum Newbie / General discussionsReplies: 4Last Post: 10th Mar 2010, 09:04 -
Req: Configuration help for best audio/video using freeware and PC
By Morcas in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 07:47
