Just downloaded ffmpegX, for my osx leopard intel mac. Converting a avi (divX) to iPhone (mp4), just outputs a completely blank video file (white, no image or audio).
Anyone any ideas?
Encoding started on Fri Aug 15 01:42:30 BST 2008
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
mp4 [info]: initial delay 0 (scale 25000)
Doesn't mean anything to me, hopefully does to someone..
There should be more lines after that. This is only the start text. Are you sure it finished?
On another note: does the AVI play well in QuickTime Player? For this preset, ffmpegX will use QuickTime to read the source file, as default. If QuickTime Player has trouble playing the file, then the same may apply to this setting of QuickTime decoding by ffmpegX. Installing a 3rd party component like Perian/DivX®/3ivX will help QuickTime (and ffmpegX) read more types of movie files.
How long did you wait? Did the Progress bar get all the way to 100%, and then say "Finished" (or Done)? If what you posted was the complete log, then you didn't wait long enough. These conversions are not instantaneous, so if you were expecting them to be, then that could be part of the problem. Depending on your computer's speed, conversions can take longer than the duration of the source.
ah you could be write, they don't play in QT (I always just use VLC) .. let me install the divx and let me see
Are there tutorials on this forum for converting AVI to a iPhone 4 MP4 cont
By rocky12 in forum Newbie / General discussionsReplies: 2Last Post: 5th Sep 2011, 09:12 -
Need help with mp4 video size for iphone
By skorpinok in forum Video ConversionReplies: 1Last Post: 10th Jul 2011, 11:00 -
Convert .avi to iPhone .mp4
By kabuto in forum Video ConversionReplies: 4Last Post: 14th Mar 2011, 03:51 -
What is the right software for me? MKV to MP4 iPhone 3GS
By zanmat0 in forum Video ConversionReplies: 5Last Post: 18th Jul 2009, 02:59 -
MKV to MP4 (iPhone)
By jwfc in forum Video ConversionReplies: 0Last Post: 28th Sep 2008, 20:39
