Results 1 to 30 of 50
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    This very basic guide will show you the steps how to convert any video to high quality flash video, MP4 with H264 and AAC audio, and put it on your website with a flash video player. Using free software only.
    Software
    Xvid4PSP (Free)
    JW FLV Media Player or Flowplayer(free)
    Preparation
    You can check how it will look like in the example below here, if it wont work be sure to update the Adobe Flash Player here.
    If you are going to convert from a commercial DVD then rip it to the HDD using DVDFab Decrypter first.
    Install Xvid4PSP.
    Convert
    Open the source video in Xvid4PSP. Click on Open to open most video formats and DVD to open a DVD or DVD folder on your HDD.
    Choose MP4 under Format.
    Choose x264 Q16 Turbo under Video Encoding. Click on the E to change advanced settings like the video bitrate that decides the output file size. Choose 1-pass(or 2-pass for even better quality but takes longer to convert) under Encoding mode and you can set the exact bitrate and get the desired output files(see the Output file size: in the screenshot below). Higher bitrate = higher quality =bigger output file size. If you don't need an exact file size then use Constant Quality / Quantizer mode.
    Choose AAC-HE CBR 64kbit under Audio Encoding. Click on the E to change advanced settings like the audio bitrate that decides the output file size.
    Choose Video->Resolution/Aspect ratio to change the resolution.
    Set the Output resolution, higher resolution usually requires that you must use higher bitrate=bigger output file size.
    Check so the output aspect ratio is similiar to input aspect ratio or it will look stretched.
    Hit Convert.
    Put the video on your site
    Download JW FLV Player and extract the player.swf and swfobject.js and put on your site with the mp4 video you created above.
    Add this code to your webpage that should display the video:
    HTML Code:
    <script  type="text/javascript" src="http://www.site.com/folder/swfobjects.js">
    </script>
    <script type="text/javascript"> var s1 = new SWFObject('player.swf','player','640','360','9.0.115');
    s1.addParam('allowfullscreen','true');
    s1.addParam('allowscriptaccess','always');
    s1.addParam('flashvars','file=test.mp4');
    s1.write('preview');
    </script>
    Replace test.mp4 with the filename of your video.
    Replace the '640','360' with the resolution/frame size of your video.
    Example
    HTML Code:
    </script>
    var s1 = new SWFObject('https://forum.videohelp.com/images/guides/355179/player.swf','player','672','376','9.0.115');
    s1.addParam('allowfullscreen','true');s1.addParam('allowscriptaccess','always');
    s1.addParam('flashvars','file=https://forum.videohelp.com/images/guides/355179/test.mp4&stretching=fill&image=flash.jpg');
    </scrip>
    Problems
    Add an image to the flash player by adding the &image=flash.jpg to the flashvar setting,
    s1.addParam('flashvars','file=test.mp4&stretching=fill&image=flash.jpg')
    If you can't see the video in your web browser be sure to upgrade to latest Adobe Flash player(requires at least Flash Player version 9.0.115 or higher).
    If you don't want any black borders in the player you can add &stretching=fill in the url to your mp4 file like http://www.site.com/folder/test.mp4&stretching=fill
    If you put the player and video in different folders then add the complete url to to the code like,
    HTML Code:
    </script>
    var s1 = new SWFObject('http://www.site.com/folder/player.swf','player','640','360','9.0.115');
    s1.addParam('flashvars','file=http://www.site.com/folder/test.mp4');
    </script>
    If Xvid4PSP wont work you can use other all-in-one h264 converters like HandBrake, StaxRip, Ripbot264, avidemux.
  2. How does this application compare to ON2's very awesome encoder?
    Thanks in advance!
    Julian Maytum
    I haven't compared the x264 converter with the on2 converter but I guess you should be able get similiar quality if you know how to configure correctly. I just want to show a free alternative to on2 and flash professional.
  4. I'm giving it a go.. thanks for the great guide.. I will let you know how I make out I would like to use this to replace ON2 hopefully and also to use it to encode video files for my Samsung Instinct!
    Thanks again for the guide!
    Julian Maytum
  5. I will try this as well in the next couple of days and report back
    Bringing your photos and memories to life
    www.YourHighlightFilm.com
    Aug 2008
    Switzerland
    Excellent guide, thx!
    One point is not clear for the code.
    You mention:
    After the size, what is the third figure standing for - resolution?
    Sometimes you mention '9' and others '0'
    If it's standing for the resolution how does this work?
    thx
  7. Member Soopafresh's Avatar
    Jan 2004
    This is a great guide, Baldrick!
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    You mention:
    thx
    It should be 9. It is the required flash player version. You can add 9.0.115 so you are sure the user has upgraded flash with h264 support (and add a link to the upgrade, see the example above)
    See http://blog.deconcept.com/swfobject/
  9. why not use 2-pass encoding if you have the extra time = better quality video
    this method works pretty well if your converting a shorter video, but not so good if your video is anything over a couple of minutes long
  10. Baldrick, What is this 'XviD4PSP 5.0 source code 28.02.2008' file and do I need to download and install it to use Xvid4PSP?
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    maxamillion: Added that you can use 2-pass also.
    captain satellite: Nope, you don't need the source code. Just http://download.videohelp.com/download/XviD4PSP_5034_full.exe .
  12. Baldrick, What would be the best settings for the ultimate quality video if time was not a concern, only best quality. Those settings worked great, just wondering if it could be even better.
    Thanks for a great, simple to use guide!
  13. Member waefwaeefwaefw's Avatar
    Feb 2008
    Hey bro' How can I do this through Flash CS3?
    I want to place a high quality video in my flash site.
    Can you show me PLEASE??
    Thanks.
  14. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    What a great guide !!!
    Very kewl !!!
    I'll have to try it
    - John "FulciLives" Coleman
    I love the JW FLV player..I use it on my website with the playlist feature so people can view movies, images, and songs all from the same playlist.
    Aug 2008
    Thanks Rick, this guide is great.
    Is there a way to do batch converts? I have like 100+ videos that I want to convert.
    Thanks,
    Adam
    Oct 2008
    Houston, TX
    I followed the instructions, but my video won't play. What did I do wrong? Is there a file size limit or might I have an issue with my host?
    My video can be found on www.busttheclock.com
  18. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if this is you index page then are all the required files in your root directory? both the player files and the video?
    Oct 2008
    Houston, TX
    Yes, all the files are in one folder. I have several domains under my host and created folders for each one to keep them straight.
  20. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if the files are in a different folder than the html page then you need to use the url of the files. as in
    [edit] i can't seem to type in the text without it thinking it's a video to play
    anyway the files need full url addresses - 'http://www.yoursite.com/folder/player.swf','player','672','480','9.0.115'
  21. I'm a MEGA Super Moderator Baldrick's Avatar
    aedipuss: Use the -bbcode for html in this forum section.
  22. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    thanks
    that will put it in a quote like box and not run it?
  23. Member
    Oct 2008
    Houston, TX
    The html page, .mp4 file, swf player, etc. are all in one folder.
  24. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    your source code is missing part of the scripts first line - it should b like this
    and i would still use full urls for all files. you might also reduce the flash player version to 9.0.115
  25. Member
    Oct 2008
    Houston, TX
    The disclaimer takes away the player when you add it to the script. The full address isn't doing anything. I did reduce the flash player, however, to the older version. Do I need to add %20 or whatever the characters are when you save a pdf in a certain application since I have spaces in the title of my video?
  26. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    it's possible your server can't deal with spaces in file names. i use the _ to connect rather than spaces.
    the first line i posted works, it's right off a page on my site and it's what baldrick used for the video to play in this thread.
  27. Member
    Mar 2007
    Netherlands
    There is something I don't fully understand. The code adds the JW FLV Player to the site. I thought this player can playback the MP4 file. Then why is it still required to have Adobe Flash Player version 9 or higher? I thought that you need EITHER Adobe Flash Player 9 OR JW FLV Player. Could someone explain this in more detail? I am confused about this.
  28. I doubt this player works any longer. I can't get any of this to work as before.
  29. Can anybody explain to me why this player won't work? I even added the whole url for everything even though it's all in the same folder. I did this a while back. Here's my link and code. Please help,
    http://myfavoritevideoclips.com/videopage/index.html
    The player will show in this paragraph
    Edit: Great the code isn't showing up.
