Also why does XP not read them anyway.
Maybe you need to load the UDF2.60 extensions? I don't remember XP having anything other than 1.02.
Try creating an .ISO file of your disc and see if info can be extracted that way (NERO should be able to do this).
Or, are you trying to play something on the disc?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
You didn't say what kind of discs..
CD and DVD don't really use v2.60, that's almost always BluRay/HDDVD. So installing an appropriate player for them usually installs the v2.60 filesystem support.
Or you could use ISOBuster or other similar reader...
Scott -
You could try the UDF 2.xx driver from Toshiba:
toshiba_udf_driver_hddvd_25074a_inf.zip
Panasonic DMR-ES35 fails to read discs
By lilblu in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Sep 2012, 13:14 -
Samsung HT-Z310 Doesn't Always Read (DVDs) Discs
By V Bot in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Feb 2011, 20:48 -
Toshiba SD-290 - Not Reading Burnt Discs (I've read the sticky)
By irish-sid in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Feb 2011, 09:06 -
LG RH1888H unable to read discs
By robin c in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Nov 2007, 09:48 -
Philips DVP5960/37 Won't Read Discs
By synchro505 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 01:57
