Ok.. I'm in a dead end here. I have a .avi video that I can't play on my PS3. I tried everything I know and I could think of and found on the net, but no luck. I tried to re-encode it to Xvid and DivX using VirtualDub, re-encode the audio, changing the FourCC, used MPEG4Modifier to change the packed bitstream (as I heard it might affect the playing).
But when I cut a part (any part) from the video using VirtualDub it works on the PS3.. but the whole video doesn't work.
So, can anyone help me here. I'm beginning to think that my PS3 hates this video as all my other videos works fine.
Thanks in advance.
PS3 has a limited AVI size support, I think less than 2GB
It doesn't support large AVIs, Open-DML
You must split it -
Try running it through these apps. Both tend to 'fix' a few things.
http://alexander-noe.com/video/amg/
http://fixounet.free.fr/avidemux/ -
Thanks MysticE, it worked. I used the first app. But there is a noise in the first 9 sec, which according to the app. it's the audio delay.
Is there a way to remove it?
NVM, I'll just try to split the audio from the video and cut the noise and join them back together.
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 15:28 -
X264 AVI file to play on PS3??
By bagmand22 in forum DVD RippingReplies: 1Last Post: 25th Jun 2010, 07:19 -
Burn .avi files as what type of dvd for playing on PS3
By VenGeanCe in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2010, 17:56 -
Playing Ripped Blu Ray on PS3 - Audio Problem
By toranaBob in forum Blu-ray RippingReplies: 0Last Post: 24th Feb 2009, 18:26 -
AVI to DVD playing on PS3
By silv in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 14:06
