im trying to portforward with my westell 7500. but i cant get into my router. i tryed http://portforward.com/english/routers/port_forwarding/Westell/D90-327W15-06/pcAnywhere.htm it saids that admin is the pass, but its not working. i also tryed my verizon name and pass and that didnt work. should i restart the router then try to get into the router (before i reconnected with verizon)?
i don't know about a westell, but most routers have a tiny hidden button to press that resets them to factory specs. that might get you back to admin as the password.
How do I change my Westell VersaLink 7500 password? Verizon : Change portal
If you have a Westell VersaLink 7500 modem and have recently changed your Verizon Online password, you need to follow these instructions.
Open a Web browser and type 192.168.1.1 in the address bar. The Enter Network Password screen appears.
In the User Name field, type your Verizon Online user name.
In the Password field, enter your previous Verizon Online password, and then click OK. The Westell Advanced Home screen appears.
Note: If the Westell Advanced Home screen does not appear, try again using the Westell VersaLink 7500 default user name and password settings:
Default user name: admin
Default password: password
In the Connection Overview area, click edit. The Edit VOL Connection screen appears.
In the Account Password field, type your new Verizon Online password.
Click Save.
A confirmation box appears to make sure you really want to save your new password. Click OK.
https://www22.verizon.com/foryourhome/eRepairNet/DSLRepairANR/Common/SupportDetails.aspx?case=R7500
Don't know but it looked worth a try....
-PB
Wireless Router Problems With Samsung Galaxy S2
By Nitro89 in forum ComputerReplies: 4Last Post: 8th Nov 2011, 15:55 -
Possible router problems.....
By SE14man in forum Newbie / General discussionsReplies: 21Last Post: 25th May 2009, 22:05 -
Wireless Router Problems Effective Range?
By scustalow in forum ComputerReplies: 3Last Post: 30th Jun 2008, 20:06 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34
