Newbie here trying to figure out the settings I need for Premier 5.1
I have my edited video file done in Premier and now I'm ready to export it. There are several settings for video for the framerate and such, can anyone give me the settings I need to create the file for eventual use on a VCD. I understand that I will need to convert the file before burning it to a CD.
I was also wondering if settings I set at the begining for my project have any effect also.
Thanks,
P.S. I would just like to give my high appraisal of this site also, seems like they have evrything covered for video editing.
You can use an MPEG-1 plugin (e.g., Panasonic, bbMPEG, CCE) with Premiere so that you can export directly to MPEG-1.
Else, you could use AVISynth with Premiere to frameserve to an external encoder (e.g., TMPGEnc).
Both ways will prevent you from needing to go through an intermediate AVI step.
As for the settings, you should make sure that the settings are correct when you start your project and for export.
For VCD, the framesize should be 352x240 for NTSC and 352x288 for PAL. The framerate should be 29.97 for NTSC and 25 for PAL.
You'll find more info if you click on "What Is VCD/SVCD" on the menu to the left.
Regards.Michael Tam
w: Morsels of Evidence -
Thanks again for the info. I have downloaded one of the suggested products and will give that a try.
Is there any reason I should upgrade my premier to do VCD's? I just wondered if it would be a waste of money if can do it with what I have now, 5.1. -
Unless you intend to use DV Video camera footage, like home movies, do not bother to upgrade.
TOMMO -
Is their a preferred method. Why would I use the CCE plugin as opposed to Avisynth in Premiere and vice versa. Is one better/easier then the other.
Choosing right settings for editing HD .mov files in CS4 Premier-PC environ
By Downing32 in forum Video ConversionReplies: 24Last Post: 28th Jan 2013, 17:36 -
Encoding HELL!!! Someone please help
By web_maven in forum Video ConversionReplies: 7Last Post: 7th Dec 2011, 09:42 -
So how the hell did they do this??!!
By Chilla1142 in forum EditingReplies: 9Last Post: 1st Jun 2011, 09:46 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
HV30, Premier Pro CS3, Output Settings
By aprilsnow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Oct 2008, 22:31
