I'd like to take my 1440x1080 16:9 .mts files and deinterlace them to 960x540 60fps, so how would I go about modifying the batch script for the AVCHD anything to accomplish this?
What compression formats can actually support 60fps?
Sorry if this is a repeated topic, I did a quick scan on search and didn't find much.
I'll keep hammering at this until I find something that works reasonably well.
I've tested this before, and there's something up with the PAFF hybrid interlacing on AVCHD which makes 60fps not work quite right. I'll post an example in a few minutes.
Your field order was backwards? No, you're right, it's something weird. I'll take a look later today. I have that sample MTS file sitting around somewhere.
Much better by adding an AssumeTFF() but some strange artifacts. I'll try a different deinterlacer. Thanks, jagabo.
tff_60fps.mp4 -
I just ran a quick test with AssumeTFF() and Yadif(mode=1, order=1). The results looked pretty good but I'm having some other problem with DirectShowSource() and that MTS file right now (intermittent jerks).
I saw the strange wavey artifacts in your encode. I think that was an encoding error. I didn't see anything like it in my quick Xvid AVI.
SANYO VPC-GH4 1080i 60 fields/sec reported as progressive at 60fps
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th May 2011, 22:43 -
AVCHD (1080i) ve Motion JPEG (HD)
By pemongillo in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2011, 21:05 -
60fps versus 50fps? PAL or NTSC in AVCHD?? need advice!
By ftitus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th Nov 2010, 07:11 -
experienced user looking for avchd 1080i deinterlacing help from experts
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Aug 2010, 20:25 -
Using AVCHD (1080i) instead of regular AVI-DV (480i) MINI-DV - argh!
By eddie24 in forum Video ConversionReplies: 4Last Post: 6th Oct 2008, 20:32
