I have a home theater pc setup in one room in my house, and an old analog tv with a converter box in another room. Both recieve signal from the same source; roof antenna. The HTPC using a haupaugge wintv 1800 and Vista media center 64 bit only gets 2 channels. The analog tv with converter box gets 15 channels some from cities miles and miles away. So, what is wrong? Is it a VMC problem and I should get other software - if so what? Is it the TV tuner card that is weak? (this would be dissapointing) Or something unseen? Please help.
I would lug the TV and converter box to the PC location and connect it to the antenna lead to see what's what.
I hear the Hauppauge boxes require a stronger signal than most cable boxes and TVs. Try an antenna signal booster.
HD Video signal strength
By seatrout34221 in forum Capturing and VCRReplies: 1Last Post: 31st Jan 2012, 19:56 -
1:1 signal display?
By khorven in forum DVB / IPTVReplies: 1Last Post: 28th Aug 2009, 11:32 -
video signal transfer
By longislandgrafix in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 19:15 -
No device signal
By immortal in forum Capturing and VCRReplies: 2Last Post: 11th Oct 2008, 11:59 -
Does CW do something to their HDTV signal?
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 9th Jun 2008, 08:21
