I was chatting on IM when my pc froze for a few seconds and then I got a blue screen that stated something about a memory dump. When I restarted my pc I get a "no boot device available". I can hit F1 to retry and F2 to enter bios. In bios boot sequence 1 is onboard SATA hard drive but it says "not present".
Also in bios driver section I notice that driver 1 (SATA 1) has a driver id: unknown. The dvdrom and dvd-rom drives are read and functional. I tried reinstalling xp but when it gets to partitioning section I get same no bootable device
found. The pc wasn't touched at all before this happened and I didnt DL or visit any risky sites so I know its not a virus.
I believe its either my western digital internal HD or the CMOS battery. I'm using my iPhone to post this message. Please help me and if u need any additional info please ask. Its a dell XPS gen 5.
Closed Thread
Results 1 to 14 of 14
what about that battery? I had heard it could also be the problem. Although I used Dell Diagnosis and it checked out. How could a cable get loose when the base never moves? I'll try it since I'm bored to death and have nothing to lose. I hope the 3 yo HD didnt die, that would suck. Idk if this makes a difference but I hear 2 beeps when pc starts.
Idk of any more tech specific forum out there so if anyone has any other places I should try let me know.
I have seen odd problems like this actually be caused by a power supply that needed to be replaced. Unfortunately that's a kind of expensive gamble as it might not be your problem. I had this kind of thing happen to me where my power supply appeared to be OK (the PC had power). but the hard drive would not boot at all. I replaced the power supply and everything was golden.
AFAIK, the battery is less of a problem on new PCs. In ancient days past the battery was used to back up the BIOS settings (in battery backed RAM), plus there was no plug and play, so if the battery went flat the PC could forget the correct settings for any hard drives that were attached. In this day and age the battery is pretty much only there for the real time clock since BIOS settings are stored in flash, also the hard drive is plug and play with S.M.A.R.T. tech as well.Originally Posted by majax79
Later edit: oh yes - I go with the folks who suggest a loose SATA cable. SATA is apparantly notorious for this.
From the sounds of it, it's more likely the hd has suffered a freak os snap.
I think you need to use the mbr reset first then try and repartition the drive.
Enter the windows recovery console during cd install routine, then use the command FIXMBR.
Follow any prompts and when completed, reboot system, as it dose this, turn the system OFF.
Then turn system back on and try setting up the partition again.
Ive had three compaq laptops do this before, and its not a fun thing for those owners either.
So what? You've never heard of a power supply failing that quickly? I have. Look, I told you that the power supply probably wasn't your problem, but I work in IT for a living and I see your attitude all the time - "I know that the problem can't be _________ because I replaced it ____________ ago" and then the person who said that has to eat those words. If nothing else you do works, it probably is the power supply.Originally Posted by majax79
well mr IT it wasn't the power supply and I know snotnose stuckup IT people like u who don't care about helping people...just making snide comments and acting like theyre sh$& don't stink. U really don't wanna start with me.
For the people who helped thank you so much.
End of thread
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Safe way to restart (re-boot) without the screen
By edong in forum ComputerReplies: 10Last Post: 30th Sep 2010, 18:37 -
Blue screen?
By alintatoc in forum ComputerReplies: 19Last Post: 1st Nov 2009, 06:53 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 08:56 -
PC won't boot. Only freezing at Gateway flash screen.
By rijir2001 in forum ComputerReplies: 8Last Post: 19th Jun 2007, 10:20
