  1. Anyone know a good free streaming audio recorder? Freecorder? Contains spyware? Tried audio forums but mixed reviews. Some say great, some say spyware--who to believe. Any help would be appreciated.
  2. Member olyteddy's Avatar
    Dec 2005
    A really good $20 one is Total Recorder. I've had a lcense for it for 5 or 6 years now, so haven't had to try the free ones.
  3. Member Soopafresh's Avatar
    Jan 2004
    Total Recorder is great. Here's a free one to consider: http://www.goodkatshare.com/?page_id=26
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    MP3DirectCut is simple, free and useful to do this -- as its name suggests, it records to MP3. It has a simple editing interface to cut, join and adjust volume losslessly.
    Nov 2007
    Audacity is a useful tool though it takes a bit of learning.
    You can record whatever your computer is playing. Then you can edit & amplify and export as mp3 (provided you download the lame encoder).
