Well, i have a small dilemma, and i was curious to know if there was a solution. I want to begin to record my gameplay from xbox 360.. However. I use a 32 inch HDTV (dont worry there is a point to this) and i use HDMI hookups to assure best quality.. now if you ever seen a HDTV running on 480i, you probably already know where i am going...It doesn't look too pretty. I honestly have a hard time playing at that quality.. which would completlety defeat the purpose of me recording my gameplay to begin with. So here was my question.. I dont exactly care if i record in HD or not if i can.. but is there a way to play in HD and record with a regular more common unit..
I was thinking.. ive seen those USB port plug and play capture devices (looks like a flash drive) that are made to work with computers.. so I dont know if i could just put that into a xbox. a lot of my plug and play devices work through my xbox.. my keyboard, zune, etc. etc..
Ive been wondering about this for a while so anyone that can help it would be greatly appreciated.
Thank you for your time.
-JJ
I dont know if it makes a difference.. but my TV does have a VGA input..
Capturing XBox 360 in HD
By Hyde! in forum Capturing and VCRReplies: 6Last Post: 3rd Jun 2011, 22:28 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Capturing Xbox 360 video
By lostsoul99 in forum Capturing and VCRReplies: 3Last Post: 13th May 2010, 08:33 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Capturing from xbox 360
By VirTu3 in forum Capturing and VCRReplies: 43Last Post: 21st Jan 2009, 13:11
