How do I apply a filter for certain frames, but not others?
An example might be a clip with 10000 frames. A dark scene with a single light source causes banding in frames 2000-3000. I might want to apply a filter on, something like GradFun2db, but not expose the rest of the film to it. - You get the general idea...
I'm looking for the generic syntax on how you might do this (in general, doesn't have to be that specific filter)
I know you could also encode it in segments, and even encode using quantizer zones at the encoder level, but I'm trying to learn about avisynth processing, and there's probably an easy yet elegant script that my Google search hasn't come up with yet.
Thanks for any comments
Trim lets you segment a video. e.g.
clip=AviSource(clip.avi)
clip1=Trim(clip, 0, 1999)
clip2=Trim(clip, 2000, 3000).Tweak(sat=0.5)
clip3=Trim(clip, 3001, 0)
final_clip=clip1 + clip2 + clip3
ConvertYUY(final_clip)
Breaks the source clip into parts, reduces the saturation of the second part, recombines them and does a colourspace change to the entire clip.Read my blog here.
How to apply filters to video?
By kaona in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 14:59 -
Which filters I should use for this anime? (avisynth)
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2010, 08:47 -
How to apply filters in VirtualDub to only *parts* of the video?
By maskingtape in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 03:19 -
Avisynth Filters (help pls)
By Enkidu in forum EditingReplies: 14Last Post: 30th Jul 2010, 22:41 -
[Avisynth] What are the filters used in this video?
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 10:40
