can anyone tell me why this file here only plays back pretty good on vlc and no other player including media player classic can play it? I say "pretty good" because seeking is still sloppy as it takes about 15-20 sec for vlc to clear up the pixels. I have not even tried it at the destination (Xbox 360) yet. pretty sure it will play like crap. and to clear things up this is the output file .avi that I got from a mkv file.
I do notice the the avi is a hvc codec with 6 channel audio. thats a no no for the xbox right? also I have latest k-lite codec pack full installed.
- General #0
Count : 195
Count of stream of this kind : 1
Kind of stream : General
StreamKindID : 0
Count of video streams : 1
Count of audio streams : 1
Codecs Video : AVC
Audio codecs : AC3
Complete name : G:\mkv2vobencodedfiles\ESB1.avi
Folder name : G:\mkv2vobencodedfiles
File name : ESB1
File extension : avi
Format : BDAV
Format : BluRay Video
Format/Family : MPEG-2
Format/ : m2ts
Codec : BDAV
Codec : BluRay Video
Codec/Family : MPEG-2
Codec/ : m2ts
File size : 2429417472
File size : 2.26 GiB
File size : 2 GiB
File size : 2.3 GiB
File size : 2.263 GiB
File creation date : UTC 2008-08-12 19:27:54.968
File last modification date : UTC 2008-08-12 19:32:00.859
Video #0
Count : 90
Kind of stream : Video
StreamKindID : 0
MenuID : 1
MenuID/String : 1 (0x1)
Codec : AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://developers.videolan.org/x264.html
Codec profile : Main@L4.1
Codec settings : CABAC / 3 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 3
Bit rate : 6288000
Bit rate : 6288 Kbps
Nominal bit rate : 6288000
Nominal bit rate : 6288 Kbps
Width : 1904
Width : 1904 pixels
Height : 816
Height : 816 pixels
Pixel Aspect Ratio : 1.000
Display Aspect ratio : 2.333
Display Aspect ratio : 2.35
Frame rate : 23.976
Frame rate : 23.976 fps
Chroma : 4:2:0
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.169
Delay : 600000
Delay : 10mn
Delay : 10mn
Delay : 10mn
Delay : 00:10:00.000
Writing library : x264 - core 56 svn-680
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=abr / bitrate=6288 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.3
Audio #0
Count : 75
Kind of stream : Audio
StreamKindID : 0
MenuID : 1
Codec : AC3
Codec : AC3
Bit rate mode : CBR
Bit rate : 640000
Bit rate : 640 Kbps
Channel(s) : 6
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48000
Sampling rate : 48.0 KHz
Delay : 600000
Delay : 10mn
Delay : 10mn
Delay : 10mn
Video0 delay : 0
here is the original mkv file stats
- General #0
Count : 195
StreamKindID : 0
Codecs Video : AVC
Audio codecs : AAC LC-SBR
Complete name : G:\EmSB1.mkv
Folder name : G:
File name : EmSB1
File extension : mkv
Format : Matroska
Format : Matroska
Format/Url : http://packs.matroska.org/
Format/ : mkv mka mks
Codec : Matroska
Codec : Matroska
Codec/Url : http://packs.matroska.org/
Codec/ : mkv mka mks
File size : 4463684629
File size : 4.16 GiB
File size : 4 GiB
File size : 4.2 GiB
File size : 4.157 GiB
PlayTime : 5678720.000
PlayTime : 1h 34mn
PlayTime : 1h 34mn 38s 720ms
PlayTime : 1h 34mn
PlayTime : 01:34:38.720
Bit rate : 6288296
Encoded date : UTC 2008-08-12 03:14:06
File creation date : UTC 2008-08-12 03:14:06.171
File last modification date : UTC 2008-08-12 03:19:21.312
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Count : 90
StreamKindID : 0
UniqueID : 3740004285
Codec : V_MPEG4/ISO/AVC
Codec : AVC
Codec/Family : AVC
Codec/Url : http://ffdshow.sourceforge.net/tikiwiki/tiki-index.php?page=Getting+ffdshow
Codec profile : High@L5.1
Codec settings : CABAC / 16 Ref Frames
Codec_Settings_RefFrames : 16
PlayTime : 5673041
PlayTime : 1h 34mn
PlayTime : 1h 34mn 33s 41ms
PlayTime : 1h 34mn
PlayTime : 01:34:33.041
Width : 1904
Width : 1904 pixels
Height : 816
Height : 816 pixels
Frame rate : 23.976
FrameCount : 136153
Chroma : 4:2:0
Interlacement : PPF
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=240 / keyint_min=24 / scenecut=40(pre) / rc=crf / crf=18.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30
Audio #0
Count : 75
StreamKindID : 0
UniqueID : 2624092345
Codec : A_AAC/MPEG4/LC/SBR
Codec : AAC LC-SBR
Codec/Family : AAC
Codec/Info : AAC Low Complexity with Spectral Band Replication
PlayTime : 5678720
PlayTime : 1h 34mn
PlayTime : 1h 34mn
Channel(s) : 6
SamplingCount : 272578560
Resolution : 16
Resolution : 16 bits
By watching the full details of the resulting encoded file and the original MKV, I give my humble opinion :
1) Playback
The original MKV has a full-hd resolution
1904 x 816
If your CPU isn't a at least a dual-core, then forget it....
Is easy to check : play your file in MPC...and then check your CPU usage, if it is close to 100% usage.....that means that your CPU is out of breath almost having a heart attack
you can't play it smoothly in your PC like that
To get things even worst..add a graphic card without HD acceleration ... and you will get the worst media machine for HD playback
720 max resolution, HD-Ready, should be your maximum choice
2) I don't like MKV2VOB resulting quality, is a good tool, but in my opinion gives a crap quality
Mostly it transcodes video to a MPEG2 stream in a Blueray container or other....
What it does is to keep original resolution when transcoding to a lossy MPEG2 format using Mencoder, not the best transcoder for that
It's easy to figure that out just analyzing the output file with MediaInfo and checking the tools it uses, and man figures what it does and how it does, no logs are needed to guess that, even the audio is changed from the original
Just look at this images :
Original HD Image - ERAGON.MKV
VOB/MPEG2 - Quality using MKV2VOB
VOB/MPEG2 using HCEnc
Notice the lost of details in the guy's face to much obvious, and also look at the floor colors
Rather than keep original resolution in a crappy lossy codec, is much better to downsize to a DVD compliant resolution using a good encoder such as HCEnc, or CCE
tsMuxer, however, is by far the best choice because it is only a container transporter
3) XBOX
I think it can play fine a DVD, and AC3 is the standard supported either by PAL and NTSC
Hope this helps -
thankyou so much for your help!
I notice that tsmuxer is really geared for ps3. any help for xbox360? only real thing I see doing with it is downgrading h264 from level 5.1 to 4.1 so xbox can play it. but to a ts file? what is the xbox going to do with that?
no, my pc is a powerful beast. amd X2 5000+ over clocked to 3.13Ghz with 2 gigs ram and a geforce 9600GT over clocked edition.
will give that ts program a go. I think I have already but I have probably every freeware video tool from this great site so my head is spinning lol. take care. -
Sooner or later, M$ should give support to Blueray
Xbox can play .ts files through windows media center
Here you have a tutorial to convert AVCHD ( mts ) to Xbox
http://www.vimeo.com/629815
There is also tutorials to convert to WMV-HD using TmpGenc...search in google
Converting to a DVD-DL I think it is a good alternative also, you loose HD but not audio quality if you make just a audio copy. And when applying a good resizer...then...
A DVD-DL made with HCEnc or CCE, if you look close to the image/details/colors - as I showed in images - they look much better in quality ratio than a pseudo Mpeg2 MP@HL profile produced by MKV2VOB -
yep google is your friend all the time. sometimes I hit a wall in thinking of search terms. isnt tmpgenc a payware program?
thats cool vimeo has tutorials on this stuff. great site that is for HQ HD video.
thanks again delta2. great help
and I didnt know xbox could play those ts files through media center. I dont think tsmuxer got the sound out of the file.
mkv2vob always hangs on dts to ac3 and problems with PS3 media server
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 15th Aug 2010, 19:08 -
MKV2VOB Audio Problems
By mnalmeid in forum Video ConversionReplies: 2Last Post: 29th May 2010, 19:03 -
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 16:43 -
Using Mkv2vob to convert mkv to avi with subs.
By spunge85 in forum Video ConversionReplies: 2Last Post: 11th Jan 2010, 15:21 -
Mkv2vob problems...
By Raven2827 in forum Video ConversionReplies: 5Last Post: 12th Jan 2009, 20:44
