    Aug 2008
    Ireland
    Hi Folks,
    Very good website here,very informative.
    I'm looking for a free easy to use program that can convert FLV video files (like YouTube Video's)
    to DIVX.
    Thanks.
  2. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    Try VDownloader (www.vdownloader.es).
    It has an internal search-function and can
    download and convert it automatically.
  3. Member michcio's Avatar
    Jun 2008
    I always convert my FLV files to AVI's with MediaCoder...works really easy..then you can sure find a AVI to DIVX converter if you want to have your video in DIVX that badly::
    cheers
    michcio
    take a look at my DVD-authoring guide :)
    https://forum.videohelp.com/topic353434.html
