I have a problem that has happened twice now,
when i rip a dvd, i pull it off with dvd decrypter into a file, then i use vobblanker to remove things i dont want, then i run it through fixitvts to clean it up..
so im left with a movie folder, normally i take it to dvd shrink, to shrink it, but this time it was small enough to fit at the beginning, dvd shrink says it is 4162MB, well short of the 4464 limit,
so when it doesnt need to be shrunk, i exit shrink, and open imgburn, and go to 'folder to image' (i like to make an iso first), but img burn asks me for a layer break position, and tells me that the iso will be over 5000mb....
the movie folder itself says that it is 4.79gb
how come theres all this discrepancy, is it my fault?
what should i do?
ok i went ahead and created the 5000mb image that imgburn said it was, but, after its done, the imgage file says its only 4915mb
If your video folder is 4.79gb ,then it won't fit a DVD-5 disc which only holds 4.37gb.....
https://www.videohelp.com/dvd
"In the computer world is 1 KB data = 1024 bytes so 4 700 000 000 bytes / 1024 = 4 589 843KB / 1024 = 4482MB / 1024 = 4.37GB. See section 3.3 in the DVDDemystified FAQ here." Who needs Google, my wife knows everything" -
but dvd shrink says it will fit on a regular dvd, and only shows it as 4162MB
its weird -
Not sure what your prob is, here's a sample of mine...
As you can clearly see it's actually a larger file than your 4162 mb file.....
Just run it through shrink and create an ISO as teh output and see what size that is.
My guess is that the way used vobblanker and fixvts etc. has left a layer break setting in there that running it through shrink may fix.
Odd breaks in video/audio authoured with DVD Shrink 3.2 & Imgburn
By bahjan in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2010, 14:46 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 22:35 -
Known problem with ImgBurn or DVD-Shrink?
By stockjunior in forum Authoring (DVD)Replies: 5Last Post: 26th Feb 2009, 16:12 -
Dvd Shrink + Imgburn
By angryassdrummer in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 00:54 -
burning with dvd shrink/imgburn
By angryassdrummer in forum Authoring (DVD)Replies: 4Last Post: 7th May 2007, 16:44
