Is there a way to have a video clip then extract the audio of it into mp3?
My pc has a sound recorder but it loses noticible quality when i record from the sound as it plays....
Thanks in advance for any help....
I use VirtualDub Mod for MPEGs or AVI type formats. You can demux or save out the audio as a WAV. I use the WAV in the freeware audio editor Audacity to edit and convert to MP3 with the addition of LAME MP3.
MPEGs may use MP2 or AC3 or other audio formats, so you may need to install a AC3 decompresser or others for VDM to read those files. The newer VD can also do this, but you need to add plugins.
MP4s may be a bit more difficult, depending on the video and audio formats. -
AOA Audio Extractor is as simple as it gets, if you just want the audio track.
http://www.aoamedia.com/audioextractor.htm
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
Exact audio copy refuse to extract to Mp3 now
By Blå_Mocka in forum AudioReplies: 8Last Post: 14th Nov 2010, 04:19 -
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 04:11 -
question about how to extract mp3 audio from DVD
By jimdagys in forum AudioReplies: 5Last Post: 17th Apr 2008, 10:19
