Hi Guys,
I provide alot of tutorial content for Youtube and I use Hypercam to record my tutorials. I use 10fps when recording my tutorials (my PC can't keep up with 30fps) and use the H.264 codec with a bitrate of 1000kbps with dimensions of 640x480. The problem is that because my tutorials are low in motion they usually have a bitrate of anything in-between 261-350kps (when checked with Gspot). This is a problem because I would like my Youtube videos to have the "High Quality Link" available so that my subscribers can see the tutorials at full quality. The reason this link is unavailable is because in order for a video to be classed as "High Quality" it must have a bitrate of 600kbps or more. So my question is there anything I can do to make sure my video stays over a certain bitrate??, I have even tried using a bitrate of 10000kbps when recording my movies but that still doesn't work.
Any help would be appreciated...
-Regards
DM.
Hi Guys,
Thank you for the responses so far however I still haven't found my answer. I did as you said and used a lossless codec first to make my recording. The file was huge and so was the bitrate which was to be expected however after compression with the H.264 codec at 1000kbps the final bitrate of the file was only 256kps (when checked with Gspot) which of course is far short of the 600kbps second mark. I even used DivX and specified a bitrate of 2000kbps and it came out nowhere near that mark. I can't upload the uncompressed version onto Youtube since it's far to large. I am thinking this is a low motion problem. Is there anything I can do to ensure my encoded clips come out with a bitrate of 600kbps or more?.
-Thanx Again
DM.
Please help with YouTube low HD quality
By MindBlank in forum Video ConversionReplies: 6Last Post: 21st May 2010, 10:24 -
How to watch YouTube videos in low quality?
By ryan14 in forum Video Streaming DownloadingReplies: 9Last Post: 6th Apr 2010, 23:13 -
Youtube: why the low volume?
By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 06:07 -
Low quality youtube video WHY?
By yunakokimama in forum Video Streaming DownloadingReplies: 0Last Post: 29th Oct 2008, 15:58 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
