hi through reading and experementation i have solved a lot of my previous problems but..
i have downloaded several films at 25or 29.7 fps with a resolution of 352x288 i have encoded them using tmpgec then burnt them as pal vcds using nero nero has not reencoded them in any way but the finished quality is still not as expected ie it is grainy and fuzzy .not at all sharp so can any one guide me as to how i can now improve the quality i am playing them on a dvd player and on the tv
thanks in advance
So you downloaded compressed videos off the net, then recompressed them with tmpeg enc, and the quality isn't top notch? The hell you say! No, seriously, this is called GarbageIn-GarbageOut, you can't reencode movies and expect better(not even equal) quality since the video data has already been removed and you're removing more. If it's something you really want done right then find the source on dvd and convert it to the format you want.
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 11:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 08:28 -
VirtudalDub - edited video but quality became bad, how to resolve?
By samoyed in forum Newbie / General discussionsReplies: 15Last Post: 30th Jan 2009, 19:14 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57
