I just bought the Neoya x2vga 2.0 for my xbox 360, to capture pictures on my computer. The Neoya allows me to hook up the Xbox 360 to my PC monitor, giving me high definition visuals.
When I click the print screen key, an image of the desktop is taken, not the game.
The monitor works for the computer only when I turn off the x2vga.
So how can I create screenshots? Thank you.
Here is the schematic of my system:
It looks like the video goes directly to the monitor and you can't capture anything then. You must connect the xbox video output to your computer(like svideo in on a video/capture card).
Thanks for your response Baldrick.Originally Posted by Baldrick
I was thinking if I got a video splitter, (see image) that this would work?
But the problem is that the computer VGA monitor port is for output, not input, correct?
Response from Neoya:
On 8/13/08, sales@neoya.com <sales@neoya.com> wrote:
Dear Customer,
Thank you for your email.
Our product is aimed at improving the display quality and has no recording or screen catching function. But it won't affect or change your original audio output or other auxillary functions. You can operate it according to your original methods (before X2VGA 2 was connected).
Hope to be at your service soon! Thank you!
Xbox 360 Capture question
By unp0ssible in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2011, 20:41 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Capture Card xbox 360
By Mastapka53 in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2010, 13:50 -
Xbox 360 Capture Help?
By X Kin in forum Capturing and VCRReplies: 0Last Post: 14th Sep 2007, 11:43 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
