Hi All,
Recently, one of my DDR 333 256MB stop functioning. So, I thought I can upgrade the RAM to 2 modules of DDR 400 1GB . I am using Soltek SL-75FRN2 which support DDR 400 upto 2 GB. When I plugged in the new RAM modules, I got all sort of BSOD error codes. What baffled me was that the error code kept changing. I noticed that when I plugged in 1 module the problem goes away. Is this BIOS issue ?
Thanks in advance.
	I had problems when I put in my new memory , I found out that it ran at a slightly higher voltage than my previous memory , so I had to up the voltage in my BIOS then install it - everything now runs ok , although I havent tweaked it at all .
	Maybe you need a bios update. Check Soltek website.
 Did you check each DDR separately ??? Maybe one of them is defective ?
	Thanks for the reply. Good point I didn't up the voltage. I swap the modules and both work fine on a single module. BIOS update is dreaded thing and the Soltek website is all but gone. I think this company has gone under.
  Windows 7 BSOD after upgrade from VistaBy Poppa_Meth in forum ComputerReplies: 11Last Post: 30th Dec 2009, 06:51
  BSODBy Willy5157 in forum ComputerReplies: 10Last Post: 19th Oct 2009, 15:55
  RAM upgrade?By mvp in forum ComputerReplies: 6Last Post: 11th Sep 2008, 01:09
  What RAM I can use for upgrade?By lordsmurf in forum ComputerReplies: 19Last Post: 17th Dec 2007, 23:45
  Toshiba Satellite Vista laptop won't recognize ram upgradeBy edong in forum ComputerReplies: 17Last Post: 25th Jul 2007, 22:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
