Hi everyone,
I've just replaced my old TV capture card with a DC10+ card, when I start VirtualDub it still list the old capture card. This is OK when I can swap capture card, but when I use Premier it says it cannot connect to the (old) capture card and I cannot chose the DC10+. How do I completely remove the old capture????
Andrew
Check your Computer Properties and hardware list. If it's there remove it.
or
Goto Start - Settings - Control Panel - Multimedia. If your old card is listed remove it.
or
Goto the site http://www.pinnaclesys.com/support/display.asp?FileID=73&ProductID=307 and download the file regdelete.exe and follow the instructions on the site. It will remove all the registry entities for capture cards including DC10+. You need to install you DC10+ again after using this. I have tried that and it removed my old card completely and after installing DC10+ software/drivers it worked with no problems.
Hopefully this helps.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
