Whenever i convert my .m2t files to .mov's, then import them into final cut, they are out of sync. Why is this?
I'm using the Apple DVCPRO HD 720p60 codec, uncompressed sound at a frame rate of 29.97.
has anyone else experienced this?
Just curious (because I have no experience with DVCPRO), what would happen if you exported to "just" DV? Would you lose the 720p aspect ratio?
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
MPEG Streamclip audio sync issues
By notachancegp in forum Video ConversionReplies: 15Last Post: 3rd Dec 2010, 10:09 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
MPEG Streamclip issues - 100% CPU usage, unusable...
By semmel in forum Video ConversionReplies: 6Last Post: 27th Dec 2009, 18:27 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
