Results 1 to 19 of 19
  1. Member majordad's Avatar
    Aug 2008
    I successfully created a DVD using DVD Flick from an AVI filel,but it iwll not play in any of my DVD players. What might I be doing wrong?
    Does the dvd work on your computer?
    Did you burn using dvd flick(imgburn) also?
    Dec 2006
    Here,where do you think?
    What media are you using? What speed are you burning them?
    Does the converted file play fine from PC,before burning???
    Using IMGburn to burn or ner0?
    Edit: guess Baldrick beat me to it...
    " Who needs Google, my wife knows everything"
  4. Member majordad's Avatar
    Aug 2008
    yes it does and yes i did.
    Cubs win in 08'!
  5. Member majordad's Avatar
    Aug 2008
    t0nee1 - i used a dvd-r. not sure the speed. i accepted the default. the avi files plays fine on my computer as does the burned dvd that was created. and i used imgburn with dvd flick.
    Cubs win in 08'!
    Dec 2006
    What about the media?as in Sony,HP.....Verbatims are what I and others recommend..
  7. Member majordad's Avatar
    Aug 2008
    media?
    Cubs win in 08'!
    Dec 2006
    Disc type? e.g. verbatim,Sony HP, etc...
  9. Member majordad's Avatar
    Aug 2008
    what brand of media...ok, i gotcha. the one i just did is a TDK.
    Cubs win in 08'!
    Dec 2006
    Gotcha back, that's most likely the problem..Try better media,as in VERBATIMS...
  11. Member majordad's Avatar
    Aug 2008
    you really think that is the problem? what about a maxwell?
    Cubs win in 08'!
    Dec 2006
    If you want to add to your coaster collection or create another frisbee,by all means use the maxwell's....I've had better luck with Sony or memosux...
  13. Member majordad's Avatar
    Aug 2008
    well ok then, i'll trust your opinion!
    Cubs win in 08'!
    Dec 2006
    Well then I'll definitely sleep better knowing you trust my opinion...
    But remember,it's just an opinion,I could be wrong!
    Good luck with the very reliable verbs....... : 8)
    Dec 2005
    Canada
    Maybe DVD Flick output a PAL disk and you need NTSC.
    Feb 2006
    This is s great tool. However, I've run across a puzzling problem. When I downloaded this particular .mkv file, the Bitcomet program has a playback function that shows the subtitles for the video. However, when I tried a test burn DVD files to my PC and then to a disk, the menu shows the subtitles a "disabled". Oddly, I can get VLC Player to play it from the .mkv file, too. But when I try with my Nero program or play the DVD files from VLC, they don't show up, I can't get it to "Enable". If I play this on a standalone DVD player, will show the subs without choosing to, or am I missing something? When the files were unpacked, I found no .SRT file.
    Am I going to have to download some sort of .mkv subtitle extractor, or am I missing a setting in DVD Flick?
    Feb 2006
    Okay - I tried adding a new .srt to it, since it wasn't displaying the original that must be coded into .mkv. Now, for some reason, DVD flick won't burn the video files - only the menu files - not the actual video. I have noticed that when I try to burn it with the new subtitles, I get this message: "Warning: the subtitle has overlapping timestamps. DVD flaick will attempt to fix them, but the resulting DVD may end up truncated". Anyone?
  18. Member
    Dec 2005
    Canada
    Load the srt file in Subtitle Workshop.
    Click Ctrl I and it will show the lines with the errors and optionally fix them.
    Feb 2006
    Thanks. I'll give it a try and report back.
