I have an 8GB .mkv movie file and I want to convert it to dvd but I don't want it to shrink down to 1 dvd. I'd rather have it on 2 DVD's if that will give it better quality. I know that during conversion you will lose quality, but is there a way I can lose less quality by somehow having the output on 2 DVD's?
Results 1 to 9 of 9
You could try FAVC and you should be able to output it as two DVDs. Or ConvertXToDVD for a payware solution. It will likely be higher quaility than using one DVD, but a lot depends on the running time of file and the bitrate you end up with.
I can think of three options
1. Create your own avisynth scripts that use the Trim statement to split the file into two parts, then encode each script with FAVC.
2. Encode to DVD9 with FAVC, then burn with Imgburn to Verbatim +R DL discs
3. Encode to DVD9 with FAVC, then use something like DVD Remake Pro, DVDFab Platinum or VOBBlanker to split the disc into two DVD5s.Read my blog here.
I opened the 8GB file in FAVC but it doesn't show anything about 2 DVD's. What is supposed to happen? Is it suppose to output to two folders or what?You could try FAVC and you should be able to output it as two DVDs
I have this program also, and I also loaded the mkv file into it, but it doesn't show anywhere that the output is on 2 DVD's, nor can I find any settings on that sort of thing.Or ConvertXToDVD for a payware solution
What do you mean encode each script with FAVC? And is it hard to create your own script?1. Create your own avisynth scripts that use the Trim statement to split the file into two parts, then encode each script with FAVC.
btw I don't have a dual layer burner that's why I want to get 2 dvd5's -
Neither FAVC or ConvertXtoDVD will create two DVD5s from a single source file. I don't know of any program that will automate this for you.
In fact you don't even have to write a script. Load your file into FAVC and set up your encode as normal. Before you start the process, click on the Advanced Scripting tab. In the box marked Before Framerate Conversion enter
Where nnnn is set to the number of the last frame you want encoded for the first disc. FAVC will encode the mkv file up to that point as disc 1.Code:Trim(0,nnnn)
Don't close the FAVC while it encodes.
When it completes, change the Trim statement to
And start the process off to create disc 2.Code:Trim(nnnn+1,0)
You can open your mkv file in AVI Demux to work out the frame number of your split point.
Caveat : I have not tried this personally, but I cannot see why it would not work. You lose nothing but time by testing it out.Read my blog here.
Another option would be to use mkvmergegui, use the "split" function to split into 2 mkv's, then process 2x DVD5 from 2 .mkv by your regular method
That's what I'd do, works a treat.....Originally Posted by poisondeathray
" Who needs Google, my wife knows everything"
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 07:55 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
How do I split my 8gb MKV file in half?
By y0ungSir in forum Newbie / General discussionsReplies: 9Last Post: 1st Jul 2009, 15:36 -
8GB mkv file burned to DVD+DL
By ck_kent in forum Blu-ray RippingReplies: 10Last Post: 24th Mar 2009, 21:21 -
Convert .mkv to DVD5's or play on Xbox360
By Ryski84 in forum Video ConversionReplies: 3Last Post: 6th Jan 2009, 18:15
