  1. Hello, I have tried WM COnverter, Replay Media Capture, Orbit and Media Downloader and none can seem to capture NBC Olympic streams. It uses Microsofts Silverlight technology. ANyone have any idea how to save these streams to HDD?
    Jan 2007
    Did you try to use realplayer record feature or this program.
    http://www.mediafire.com/download.php?2ymltg5jydz
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    You can always try the old but trusted method of connecting the TV out of your video card to a stand alone DVD recorder.
    The video should play full screen on the S-Video output so you just need a stand alone DVD recorder.
    Not the prettiest or fanciest way but hey it works!
    - John "FulciLives" Coleman
  4. I don;t have s-video, my video is intergrated w/the mobo, there must be a way!!
  5. some of them i was able to download the wmv with orbit grab++, but others aren't streamed the same way, they are in couple hundred little pieces of separate audio and video. i couldn't find any way to put them back together.
  6. This guy found a way, but it does not work me? Can anyone else verify this method works:
    "Silverlight sh_t
    The Video codec is WVC1 AND **might** be encrypted
    took 15 min's of work but i did it
    you should be able to find some ASX files in
    C:\Documents and Settings\USERNAME\Local Settings\Temporary Internet Files\Content.IE5
    it WILL ALSO by pass AD'S!!!!!
    press CTRL + f to find .asx files"
  7. no asx files here, on the one's i can't get as wmv. just chunks like this.
  8. damn, oh well,i gues it is not meant to be.
    Eurosport has a great player that streams the Prime time event live that NBC tape delays for the West COast, but b/c we're in the USA it won't let me download
