I have a video clip, about 15G, that is MPEG-4 AVC. I am trying to make regular DVD, not blu-ray, out of it. The problem is I can't find any tools to convert it to mpeg2.
I have tried AllToAVI but it crashed when the converted video was even less than 1GB. Can anyone suggest me what I can do?
Results 1 to 21 of 21
ha, a 15gb clip... try the latest version of convertxtodvd, it handles just about any input format.
Try ConvertXToDVD or the freeware FAVC. If you have the same problem, maybe the file itself is corrupted.
You could also try demuxing the audio from the MKV and dealing with each part independently. Try MKVExtractGUI. -
FAVC said unable to process my .mp4 file.
I can't open my file in MKVExtractGUI because .mp4 is not supported.
It's the olympics opening video I recorded for my friend using hauppauge HD PVR. Now I am having trouble making a DVD for him and he dosn't have blu-ray player or ps3.Originally Posted by minidv2dvd
Can you play the mp4 in windows media player? If not it wont work in favc. Install haali media splitter and ffdshow.
Or use ConvertXtoDVD. -
Yes, it plays well in media player. I will try the software you mentioned.
See if you can open it with DGAVCIndex, it'll create an index file as .dga,which you can then make a text file with Notepad and save as yourfile.avs
Example: w/o knowing your file specs..Start Notepad and type this sample text
LoadPlugin("C:\dgavcdec100a32\DGAVCDecode.dll")
AVCSource("C:\yourfile.dga")
Lanczos4Resize(720,480)
Save as .avs and close Notepad
Make sure to point LoadPlugin to where you installed dgavcindex, and to location of yourfile.dga
Now load that .avs file in FAVC and process...try it,and good luck!" Who needs Google, my wife knows everything" -
Oops! I just found another problem. My source .ts file is 15.7 GB. In convertxtodvd I selected 8500 GB and it seemed it couldn't fit everything in so part of the end was cut off. I need to either split the file into two parts or find a way override the size limit in convertxtodvd.
You mean 8500 "MB" right? Try setting to DVD-9 8200 MB
Yes, 8500 MB :P
But the problem is DVD-9 is still not enough to hold the produced dvd because before I use custom settings, I did pick DVD-9. -
ConvertxtoDVD is not one of my fave tools,in fact it's at the bottom of my toolbox...FAVC is my preference,however since you're having probs using it, try by splitting your .ts file with tsmuxer using the split&cut feature..then convert each section with CX2DVD if you must....
I tried tsmuxer and cut the file into myfile.split{1,5}.ts files. Then when I opened myfile.split1.ts in ConvertXtoAVI, it seemed to recognize it was coming from a big file and actually converted all 5 files together. So I am back to ground 0, part of the video to the end was cut off. I tried just open myfile.split5.ts and convert only that, ConvertXtoAVI gave me some error messages but still converted the clip except I couldn't open VOB file at all.
I then tried FAVC route. DGAVCIndex does open my original .ts file and create a .dga file for me. I created a text file, .avs, like this:
LoadPlugin("D:\Video_Editing\DGAVCdec\DGAVCDecode.dll")
AVCSource("D:\olympics\myfile.dga")
Add this file in FAVC and click on Create DVD and get an error message:
FAVC is unable to process the following files:
D:\olympics\olympics.avs
Generally this problem occurs when the correct version of AviSynth is not installed (v.56a or greater),
or the corresponding codec is not installed........
This is frustrating
but I will try AVIDeMux
That's what I did. I put olympics.avs in the same directory with the .dga file.Originally Posted by t0nee1
Same error.
There are 3 lines in my olympics.avs file which is on my desktop. Correct? -
Start over,providing your script is correct,start Notepad and type this again,
Now while still in Notepad ,click File>save as> tick desktop, type in file name olympics.avs and save...Now you should have olympics.avs on your desktop...
And btw,here's some reading for you..
http://avisynth.org/mediawiki/Main_Page" Who needs Google, my wife knows everything" -
Followed the instruction but no go
In the meantime, I tried AVIDeMux to the point that it said:
H.264 detected .... and asked me whether i want to use save mode of not. If I select Cancel, it crashed. I am trying "use safe mode" not. But it also said that safe mode may LOST FRAME ACCURACY.... ummm...
EDIT: crashed on safe mode as well.
.TS AVC to .TS MPEG
By Kittciokas in forum Video ConversionReplies: 5Last Post: 5th Aug 2011, 13:15 -
Create a streamable mpeg-4 avc in TMPGEnc Xpress?
By KingsCrown in forum Video ConversionReplies: 2Last Post: 22nd Jan 2010, 09:20 -
Converting H.264/MPEG-4 AVC to DVD
By KiteFlyer in forum Video ConversionReplies: 1Last Post: 23rd Jan 2009, 14:36 -
MPEG-4 AVC/H.264 to SD-DVD?
By Killer3737 in forum Video ConversionReplies: 29Last Post: 2nd Oct 2008, 14:48 -
PS3 MPEG4-AVC: Just what is it, what are the limitations, how can I create?
By Colmino in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2008, 05:37
