Hi...new to the site...just bought an EasyCap USB Capture Device (obviously I want to get my videos onto PC and into longer lasting DVD's). Understood the basics. Set-up the software & drivers. Got all the right leads for connection to my VCR, etc. I understand the basics of the software and have captured quite a bit of material with sound & audio present. I'm still using the same video at the moment - quite a lot of stuff on it.
However, it all seems to be very temperamental. Sometimes I'll capture a part of the video completely fine and then - more often than not - the audio & video don't sync in the correct time. It's so annoying! Talking & speech look so stupid! I can't figure out why it's doing this. I've tried capturing from my Sky box and - every time - the audio & video syncs perfectly. The problem only arises when recording from video.
If anyone has encountered this problem and fixed it, I could really use the help & advice...I don't know what else to try. Before writing this post & wasting other peoples' time, I did scour this forum for any answers already posted but just got more confused with problems like, I may have the wrong sound card, my PC isn't fast enough, I'm recording at the wrong Frames per second, etc. Please help.
When you install Easycap most things are shaded out and are default at the frame rate for either pal or ntsc. Have you got under File-----Preferences----- general tab, under playback method high quality playback selected from the pull down menu rather than the instant playback selected. This might cause synchronization faults. Other than that It seem very strange indeed.
It could also be that your computers resources are being stretched to the limit. Sometimes all things may seem odd in real time but have you tried to burn this capture to a dvd blank just to see how the final output worked. Maybe the graphics card is showing mis match but the final burn to dvd may play in correct sync. You only have got a blank dvd to waste and see............it might come up OK.
When copying a dvd there are scene "jumps" whilst in preview but when finalised all frames and sych are working fine. Can only try!
HDMI device that can capture (unencrypted) "HD" audio sources?
By jalyst in forum Capturing and VCRReplies: 70Last Post: 28th Mar 2017, 14:45 -
What's the most "Device Compatible" container? is it, .mp4 or .mkv?
By thezanny in forum Video ConversionReplies: 11Last Post: 3rd Jan 2012, 09:07 -
Have a Magnasonic DVD816-4 Player - Bought DVDs "Probhited to play by CSS"
By Butterflyna in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2010, 23:46 -
IMG Burn "No device detected" on Linux
By A_51 in forum LinuxReplies: 10Last Post: 4th Jun 2008, 03:56 -
I just "bought" the Playboy Mansion
By Epicurus8a in forum Off topicReplies: 0Last Post: 17th Aug 2007, 05:22
