i have dvd where audio is out of sync (video is ahead of audio little bit)
can i somehow fix this?
any program where i can easily move audio forward little bit?
thanks so much for help
i mean can i use ifoedit just to add delay to audio track?
i have tried to load whole DVD (with menu) to TMPgenc author and it loads perfectly, i was even able to adjust delay -560ms but it will not load original menu....which is shame...
is there any authoring program where i can load whole dvd with menu, easily adjust delay in 1 track and keep menu intact and save with this setup?
i do not think if i demux and adjust delay and then use muxman or vobblanker to put it together..it will not keep menu and everything else intact i believe....
is there any way....? -
Originally Posted by deejay.2001
If you follow the advice given then you can fix the sync issue and keep all your menus. Baldrick and Manono have given you what you need to go on with.Read my blog here.
Can't you just use tmpgenc dvd author to fix the sync and then just replace the IFO with the menu? the files should be the same and the video was not changed, replacing the new IFO with the old one should work?
How to fix audio out of sync in a DVD without any reconverting
By Baldrick in forum User guidesReplies: 4Last Post: 11th Jul 2014, 04:47 -
Is it possible to fix audio sync without reauthoring?
By likwid8 in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2011, 00:59 -
avi audio out of sync fix?
By the_shyguy in forum Newbie / General discussionsReplies: 7Last Post: 7th Jan 2009, 21:02 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 10:07 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 16:31
