So I've been trying to convert a .wmv file to a .mp4 file. The 'conversion' lasts less than a second, tells me its finished, and then there is no converted file.
To the best of my (admittedly limited) knowledge, I have installed everything, and I'm using the 'Summary' tab because I'm not too picky on the details, I just want a file I can edit in iMovie. Can someone help? I don't understand what I'm doing wrong.
Then you would be converting to DV. If you convert to .mp4, then iMovie will convert that to DV (two conversions instead of one).Originally Posted by rcallahanb
There are several presets that generate .mp4 files. Please be more specific about your settings, e.g. the ".MP4 mpeg-4" preset, or the "h.264 mencoder" preset. In the Target format Video field, does it start with "ffmpeg" or "mencoder"?Originally Posted by rcallahanb
In the ffmpegX Progress window (where it said Finished), there is a blue "i" for every conversion. It is a button for more information: the Process Information log. It tells what ffmpegX was trying to do. Please post the results, so we can see what was going on.Originally Posted by rcallahanb
If you were using an ffmpeg preset and the last lines of the Process Information log include
"Codec type mismatch for mapping #0.0 -> #0.0"
then the solution is the set the "Invert mapping" checkbox in the Audio tab.
Inverted mapping of the streams is very common with WMV files.
Well, it doesn't matter what I convert to, because it all fails in the same way. But thank you for your help. So, with trying to convert to .DV, I get the same problem
Here's what the information window says:
Encoding started on Sun Aug 10 13:05:08 EDT 2008
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 30.00 (30/1)
Input #0, asf, from '/Users/Callie/Movies/vid1.wmv':
Duration: 00:03:48.8, start: 3.000000, bitrate: 403 kb/s
Stream #0.0: Audio: wmav2, 44100 Hz, stereo, 64 kb/s
Stream #0.1: Video: WMV3, 320x240, 1000.00 fps
So I did what you said (checking off invert mapping) and got failure and this message in the information window:
Sun Aug 10 13:07:32 EDT 2008
Output #0, dv, to '/Users/Callie/Movies/vid1.wmv.ff.dv':
Stream #0.0: Video: dvvideo, 720x480, 29.97 fps, q=2-15, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
Unsupported codec (id=0) for input stream #0.1
That would be because it is a decoding (reading) error, which does not depend on the target format.Originally Posted by rcallahanb
ffmpeg doesn't support WMV3 yet (which is the identifier code for Windows Media Video 9).Originally Posted by rcallahanb
I haven't tried it in a while, but it used to be that you could convert WMV if you had Flip4Mac installed and converted with Decode with QT activated in the Options tab. (As long as the .wmv isn't DRM'ed.)
Help converting WMV and MP4 to AVI
By ffabioo in forum Video ConversionReplies: 2Last Post: 18th Dec 2011, 13:51 -
Trouble Converting Blu-ray to Mp4
By F.Garvin in forum Video ConversionReplies: 2Last Post: 26th Oct 2010, 23:45 -
Trouble converting m2ts to either WMV or AVI using SUPER
By Royksoap in forum Video ConversionReplies: 1Last Post: 31st Jul 2009, 14:54 -
Having trouble with converting mkv to mp4 in 1080p
By NoobyDoo in forum Video ConversionReplies: 40Last Post: 18th Jun 2008, 00:59 -
Converting to MP4 from WMV problem
By tlxi228 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 07:36
