I have 3GB of memory, is it possible to have vdub load up the whole video in memory?
No. At least probably not in the sense you're thinking. You can open an AVI then preview it all or scrub through it slowly. That will cause Windows' disc cache to hold the entire file. But VirtualDub will continue to read compressed frames from the cache and decode them on an as-needed basis.
why not?
Wouldnt it be better and faster?
Besides, dont most people say you only need more memory if you do video editing? -
The process of viewing, editing, filtering, and compressing video involves decompressing the source so it can be worked with. For VirtualDub to load the whole video into memory for instant access it would have to decompress all the frames.
In theory it could load the entire video into memory in compressed form but this would make little difference to the seek speed (moving the seek bar or using the arrow keys). With short GOP material seeking to any random frame is fast enough reading from the disk (and as noted, Windows caches disk reads). With long GOP material the decoding of the GOP is the limiting factor and the cause of delays when seeking.
For filtering and compressing, having the entire source buffered in memory would make little difference in encoding speed. The filtering and compression take much longer than reading sequential frames from the disk. -
Suppose your PC had the memory to buffer an entire uncompressed video: with your design VDub would read every compressed frame and decompress it to memory before allowing you to do anything. This would be a hell of a long wait every time you opened a video clip. I think most people would find that a tad painful to use. I wouldn't call it better, and I doubt your impression of it would be "faster".Originally Posted by SignedupGuest
Good basic vid editor that can handle .mp4 movies from FujiFilm S2000HD cam
By coffeecup-sf in forum EditingReplies: 3Last Post: 21st Jun 2010, 23:24 -
Editing .wmv in Vdub
By imdaman in forum EditingReplies: 9Last Post: 9th Jan 2010, 17:09 -
MPEG-4 into vid editing software looks like shit, how can i fix?
By davidkim in forum EditingReplies: 1Last Post: 8th Dec 2008, 22:44 -
Vob / Mpeg2 editing with Vdub
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2008, 18:55 -
Coming soon: Movies on flash memory cards
By stiltman in forum Latest Video NewsReplies: 16Last Post: 4th Mar 2008, 09:58
