Hi, dear all...
I don't know if these program is REAL good or can do what exactly they said it's really able to.
If you wanna test and post any feedback, it'll be nice.
---> http://www.dvd-cloner.com/blu-ray-to-dvd/
Thanks.
Results 1 to 11 of 11
Why do people rip DVD and convert to VCD?
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Bingo! Also it would preclude the necessity of buying a dvd version in addition to the bluray just so you can rip it for portable sources like a zune, ipod, etc....Originally Posted by Xylob the Destroyer
I'm game in trying out alternatives to the pricey anydvdhd.....
EDIT - IT IS NOT A DECRYPTER!
It only rips to dvd AFTER decryption. So scratch that. I can't comment on whether or not it actually splits a bluray up into multiple dvds since I don't have a decrypted bluray disc to test it with.
I tried the four Bluray movies I own - Xmen 3, Stargate (the original with Kurt Russel), Final Fantasy, and the new Stargate Continuum. Each time it said unsupported format contains AACS - decrypt first.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Another good question! Strange the things people do.Why do people rip DVD and convert to VCD
I guess I'm out of touch ...but why would I want to watch it on my zune or ipod if I can watch it on my HD LCD?Also it would preclude the necessity of buying a dvd version in addition to the bluray just so you can rip it for portable sources like a zune, ipod, etc.... -
Why do people listen to the radio on a walkman instead of through a home stereo? The same reason - portability. Just because the quality is reduced doesn't mean you don't want to watch it in another environment besides the home.Originally Posted by videopoo
Anyway this was a bust as far as decrypting goes. It might work well for splitting ripped discs but I can't test that function.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
People rip to burn on vcd cause they only got a cd burner/dvd player and now a dvd burner/ blu ray player to rip to burn on dvd after converting.Originally Posted by Xylob the DestroyerI think,therefore i am a hamster.
I'm moving this to the blu-ray to forum as this is not news.
I would use AnyDVD and ConvertXtoDVD instead. -
Also blank DVDs (even dual layer) are far cheaper than blank Blu-Ray discs. Also (personally) I can't see the need for any resolution above the native 1388x768 that the vast majority of domestic LCD monitors offer. Anything above that has to be downconverted in real-time for final display anyway.Originally Posted by johns0
Yes, I am out of touch.Why do people listen to the radio on a walkman instead of through a home stereo? The same reason - portability. Just because the quality is reduced doesn't mean you don't want to watch it in another environment besides the home.
But why not a BD to iPod Converter then?
Because of the blasted aacs and bd+ protection schemes thats why. Just like it took decss ahwil to mature into user friendly and I might add CHEAPER so will bluray ripping. Right now anydvd hd seems to be the only game in town. I'm just not ready to fork over 80.00 for it.Originally Posted by videopooDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Blu-ray PopUp Menu with DVD Architect Pro 5.2?
By dabezt in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 02:02 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 22:04 -
What program do you use for ripping up your dvd/blu-ray discs?
By johns0 in forum PollsReplies: 19Last Post: 3rd Sep 2010, 17:31 -
Blu-Ray Program like DVD Shrink?
By PHNeedsHelp in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Jul 2010, 08:18 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
