this question probably applies to many printers that print on disc, but don't have a tray that supports "hockey rink" shaped business card CDs. is it possible to print one on this printer i have? it does allow for normal mini cd-rs, but not odd shapes.
I have the 5360. I can print anywhere I want using Photoshop.
You just need to make a template for the correct size. Then you just tell it to print to a normal CD/DVD.
BTW, my printer came with a 80mm flip over included with the DVD tray
The nice thing about the HP is that it's not limited in the print area. The bad thing about the HP is it's not limited in the print area
That means if your template is wrong, it'll print all over the DVD tray. I found that out while testing a bunch of labling programs...I now just stick to printing right out of Photoshop now. 1 file to deal with and that's it -
cool thanks. and if you were using a business card rink cd, would you line it up a certain way? yes mine came with the flip down too but the discs i have are an odd shapeOriginally Posted by stiltman
If it's round, it doesn't really matter
Now if it's those CDs that are flat on 2 sides, I would make sure the flat sides line up with the top and bottom. Then make my PS template the same way. -
it's this shape:
i guess it will be a bit of trial and error, and a bit of cleanup from getting ink on the tray -
Yep, those are a bugger to get right in PS.
I would probably use a labling software program...However in my case I never found one that actually printed right, like the one included with Epson. That's the main reason I print directly from PS.
It would also be easier to create a PS template in Illistrator
I would start out with a 80mm CD, it that's the actual size. Then I would chop off the top and bottom
Samsung BD-D5300 External HD
By pacman2000 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th May 2012, 16:52 -
Samsung HT-D5300
By aakakar in forum DVD & Blu-ray PlayersReplies: 15Last Post: 12th Dec 2011, 17:16 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
bfg tech leaving graphics card business
By deadrats in forum ComputerReplies: 6Last Post: 23rd May 2010, 13:51 -
Where to buy business card DVD-R?
By stantheman1976 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2008, 13:36
