I'm not sure if this has already been answered (did take a quick look through the forum though).... Can any recommend a dvd9 to dvd5 backup method. I have the standard dvd shrink . dvd2one etc, but I would like better control of the amount of compression used in each section. I prefer the 'do' the whole disk - extras included, obviously I would like less compression on the main feature and compress the heck out of the extrasnothing seems to give me these options. I did try the corel software but it kept removing the audio track!!
any ideas would be greatly appreciated
The free version of DvdRebuilder can apply more compression on the extras: 25%, 33%, or 50%.
Mode -> Steal Space from Extras.
For more options overall and greater flexibility, yes, look at DVDRBpro.Pull! Bang! Darn! -
I think this must be a record for reply times
thanks guys - that looks like the way forward.
Honestly appreciate the replies. I'll get the s/w asap and try it out - hope i can understand the options!!
thanks again -
I've tried 'em all over the years, and I can vouchsafe that Dvd Rebuilder PRO wins the battle.Originally Posted by MrBobFloyd
"I'm sick of paying for dinner and being served cowshit, while they give the bums eating out of the garbage my meal."
--- D. P. Smith -
DVD Rebuilder is my favorite. It takes a little longer because it actually does re-encode the DVD (A good thing). The only complaint is that it doesn't open image files directly, so you have to run it through something like Demon tool Alcohol, but I personally like doing this anyway because I've got Any DVD running so if there's any dvd structure protection it will get rid ...
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 17:52 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 11:33 -
Backup DVD9 NTSC to DVD5 NTSC in a PAL environment
By kroppkaka in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2008, 04:00 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 12:05
