    Aug 2008
    Denmark
    Hello
    By a mistake, i have formatted my harddisk. Is there any way to doing a unformat?
    I have try a program "Data recovery Professionel". A Raw Recovery find my data, but windows are unable to read the data. So i canīt get the data back to the disk. Any solutions? Using a cd, i can update the firmware. It was nice if i could do an unformat by the same way.
    /Palle
    Sep 2007
    Panasonic uses some proprietary variant of Unix on its hard drives, and so far, I think no one has been able to decipher it.
    And even if you were able to restore the drive, Panasonic recorders will re-format any drive connected to the unit, even if it has been removed from that unit and re-installed.
    So, you are pretty much out of luck
    Last edited by Anonymous4; 11th Mar 2017 at 11:11. Reason: Scrubbing myself from the Internet.
