Received this email from a friend
> > We are into reliqious song composition. We want to
> > protect the songs we sung so far and recording is the
> best
> > option. Do you know any software that we can use in recording?
> > Also, do you know any sofware for piano note reading?
What is the best software he can use for the recording?
Closed Thread
Results 1 to 10 of 10
hacking the Net using typewriter :D
For this kind or recording, I use a Hi-MD. When the recording is done just transfer the songs from the minidisc to a PC as a wav file. Edit as needed (you could use Audacity).
More info on Hi-MD on http://www.minidisc.org/hi-md_faq.html#_q101
Is this just a single microphone or multi track? For single microphone or house mixer recording to a PC most anything will work. Try Audacity (free).
For multi-track recording you will need multi mic input hardware and software.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I use Adobe Audition. It's very intuitive.
Your miserable life is not worth the reversal of a Custer decision.
I'll assume he meant a score/midi editor. Here goes a starting point:> > Also, do you know any sofware for piano note reading?
http://thedickeys.net/links/consumer/MidiScoreEditors.htm
Unnecessary job. Johann Sebastian Bach> > We are into reliqious song composition.
has already written
all religious music that we'll ever need.
We are all guessing the requirement. We need better task definition from the original poster.
If you have a decent microphone (preferably a Condensor mic with pop filter) you should be able to get professional style recordings with Acid Pro or anything similar in the Sony arsenal. I've been producing music for years (thats my job) using Acid with no problems with sound and quality. It really all depends on your mic and sound card set up. I use onboard.
I tried burning a DVD of a music recording with video.
By AKAface in forum Newbie / General discussionsReplies: 1Last Post: 12th Feb 2011, 03:11 -
Can anyone recomend audio recording software for background music?
By bweath in forum AudioReplies: 4Last Post: 18th Jun 2010, 06:12 -
Help Choosing A Laptop For Recording Music
By Nitro89 in forum ComputerReplies: 4Last Post: 31st Jan 2010, 04:26 -
Band Music Video
By sekthree in forum EditingReplies: 4Last Post: 22nd Sep 2007, 04:21 -
Sony DVDirect viable for music recording?
By auger shell in forum AudioReplies: 1Last Post: 25th Jun 2007, 11:38
