Hi,
I would like to VIDEO_TS from one DVD to iPod H.264 with one of the subtitles from the DVD.
Is that possible one of the subtitles to be inserted in the iPod file, so watching it on IPod to have also one of subtitles.
Thanx Vera
The iPod/H.264 presets won't process VIDEO_TS folders, and it won't burn subtitles onto the video, so you'll have to do an extra step:
1/ Use a mencoder preset to convert from a VIDEO_TS folder and burn the subtitles onto the video.
I think you'll find out it works faster if you use XviD instead of H.264 in step 1, as well as setting the video size right for step 2 (640/480/320 wide), so that the scaling only happens once, and in an early stage. To keep as much quality as possible in step 1, set Qmin=Qmax=2 in the Options tab.
2/ Convert the output from step 1 using an iPod/H.264 preset.
How Can I convert avi(xvid) to ipod tv out (H.264)?
By felix in forum Video ConversionReplies: 8Last Post: 1st Sep 2008, 11:27 -
Ipod - h.264 or MPEG-4, which one is better?
By FallenAngelII in forum DVD RippingReplies: 1Last Post: 10th Jan 2008, 12:12 -
converting to h.264 for ipod
By nagihcim1 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 09:27 -
Converting AVI to iPod h.264 preset
By oldskoolboarder in forum ffmpegX general discussionReplies: 1Last Post: 29th Oct 2007, 17:17 -
iPod H.264 640X480 3gp_converter hack
By ssj2_goha in forum Portable VideoReplies: 87Last Post: 12th Oct 2007, 20:01
